Welcome to the future !
Read and comment on the latest community news and site updates.
Règles du forum
Re: Welcome to the future !
Message par kwando1313 » Ven Avr 03, 2015 11:47 pm
Personally, I'm just wanting to add some features (like custom blips for characters, and other things like that) which aren't huge huge important issues, but are things that I would like to have. xP
kwando1313
Message(s) : 7683
Message par GanonZD » Ven Avr 03, 2015 11:52 pm
@Unas: I don't quite see your last point, actually. What is wrong with each module having two parts: A part that modify the editor, and a part which (if necessary) adds the corresponding feature to the player?
Ganon er kommt zum Dorf.
GanonZD
Message(s) : 523
Message par Singidava » Sam Avr 04, 2015 1:14 am
Unas a écrit :What, however, I would be happy to do is to integrate new functionalities in the AAO engine even if they are not coming from AA games - provided these features have enough potential to be reused by many people.
Given that people have been using AAO for all sort of visual novels aside from the AA universe, it could make sense to include new features from other games, or even original features.
Well, if you are willing to extend AAO to visual novel side, I suppose the obvious new features would include the possibility to change the screen size to larger, and advancement by clicking the image rather than a separate box that mimics the DS. Oh, and making the text boxes of the size of an entire image, text pauses requiring a click in the middle of it aaaaaand...
Hm. These ideas just seem to keep coming... I can't wait until the code is released. If I have time I might even contribute~
Singidava
Message(s) : 1621
Genre: Féminin
Langues parlées: Suomi, English & 日本語
Message par Unas » Sam Avr 04, 2015 1:21 am
kwando : that kind of change you'll be able to do directly in the editor code, no need for modules :-)
Ganon : nothing wrong in itself, it's a good approach on big projects. ;-)
But for a feature-oriented modular approach to be useful, you need each feature module to be independent of the rest, or have a few explicitly defined dependencies : if you edit, enable or disable one module, you don't want it to have a potential impact on all the other ones nor on the common UI.
This implies specifying precisely the way a module can interact with other modules or with the core application, which is a loss of flexibilty compared to the current way in which I just plug code where I need it. (I would probably need to revamp everything to go for an event-driven model in the player if I wanted it to be modular but still reasonably flexible.)
This also requires a fluid UI : a UI which can display an unlimited number of information (you don't want to rethink the UI every time someone adds a new module) without knowing their nature. Hence a loss of flexibilty on the UI design.
As a (bad) example, think of it this way : currently, the editor knows exactly what set of features it has to expose for a frame, so I can place them exactly as I wish. Screen on the left, music and sound on top of each other, etc.
If you take a modular approach on these features, it means the editor main interface should be able to load and handle abstract modules without knowing what they contain. The editor just knows that it has to render something for each module it loads, but delegate the rendering to the module's own code.
So, if screen, sound and music are three modules, how would the editor know that the sound and music modules are both small enough (and related enough) to be fit together ? And if I edit the music module to add an option, the corresponding area in the editor will be bigger : how will the UI adapt to that, so that the sound module is not hidden ?
Of course, it's only a silly example - you're not suggesting to split apart frame components as features, I believe. But I hope you get the idea.
While I use a modular architecture in the V6 code, it's oriented towards technical components (some modules for screen rendering, some modules for action management, some modules for editor interface, etc) : going for a well designed feature-oriented approach would be considerably more complex, and probably not needed given the size of the project !
Sing : yes, all of this would be possible improvements :-)
Message(s) : 8787
Message par kwando1313 » Sam Avr 04, 2015 1:36 am
Oh yeah, I know that. xP
I was more merely talking about what I plan to do when forking, not modules.
kwando1313
Message(s) : 7683
Message par Gamer2002 » Sam Avr 04, 2015 1:57 pm
Unas, since AAO goes open source, I propose you would create new forum section dedicated to development of AAO.
Together we will make AAO bigger than Twine and allow stuff made here to be sold on Steam.
Gamer2002
Message(s) : 548
Message par GanonZD » Sam Avr 04, 2015 2:00 pm
I support the former idea, not the latter one.
GanonZD
Message(s) : 523
Message par Gamer2002 » Sam Avr 04, 2015 2:42 pm
Come on, think about media coverage! ;D
Gamer2002
Message(s) : 548
Message par GanonZD » Sam Avr 04, 2015 2:47 pm
Yes, let us do as much as we can to attract Capcom's attention. :-D
GanonZD
Message(s) : 523
Message par Gamer2002 » Sam Avr 04, 2015 3:46 pm
Oh well, there is simple solution.
Let's fork AAO elsewhere and steal entire safely take away spotlight from Unas.
Gamer2002
Message(s) : 548
Message par GanonZD » Sam Avr 04, 2015 3:48 pm
True, let us show our gratitude towards Unas by creating our own AAO and steal his entire community. :-D
GanonZD
Message(s) : 523
Message par kwando1313 » Mar Avr 07, 2015 5:08 am
Oh right. Quick question. Any reason it's on bitbucket rather than github? (I'm just purely curious, so...)
kwando1313
Message(s) : 7683
Message par Unas » Mar Avr 07, 2015 3:19 pm
I was sure somebody would ask :-D
The first reason is that we have recently started using Atlassian Stash (the corporate equivalent of Bitbucket) in my company and I've been generally impressed with it so far. Because of that, I expect Bitbucket to offer a very good experience, and decided to give it a try.
Additionally, Bitbucket has the advantage of allowing private repositories in a free project. This will allow me to host there some files which I cannot release publicly, because of security or licensing issues. Think of the media repository with sprite and music that I shouldn't redistribute, for example. Or the actual server configuration of AAO, if I decide to version it, etc...
At last, BitBucket allows instant account creation and login for everyone who has a Google, Facebook, Twitter... or GitHub account ! It seems the simplest so that anyone who wants to contribute can login easily.
Message(s) : 8787
Message par kwando1313 » Mar Avr 07, 2015 3:26 pm
Uggggh jira is awful though ;_;
But aside from that, understandable enough.
kwando1313
Message(s) : 7683
Message par Unas » Mar Avr 07, 2015 3:48 pm
Yeah, we have started using Jira as well and I'm not that impressed with it, but I don't really care.
It's not like we will use Jira for AAO after all :-P
Message(s) : 8787
PrécédentSuivant
Retour vers News and Announcements
cron
