[E] Loop end time
[E] Loop end time
Could a feature be added, allowing to set an exact moment from which the track should go back to the beginning of a loop? Cutting it manually is pretty difficult, especially if you have whole custom soundtracks.
Re: [E] Loop end time
This has been proposed and rejected.
I'd request it regardless though - it directly influences audio of the game. I lack software to cut audio files, and even when I do that manually, it's still unlikely that I manage to cut at the right moment.
When you cut too much and save it, restoring the lost bit is impossible. When you choose the wrong loop end time, you can simply tweak the number.
- kwando1313
Audacity. It's free, and very easy to use.
Avatar made by Rimuu~
Not so easy, with 10+ tracks in a case...
- kwando1313
That takes like... 30 minutes max? It's not hard at all. You're using waaaaay longer in time in actually making a case.
