* The ability to link to custom characters, music, and backgrounds. No custom characters is not that much of a limitation, but with music and backgrounds it can get a tad irritating. You see, I have dialup, and being able to use MIDI versions of the songs would greatly help in making cases, because at the moment I am making my case without sound.
As for custom characters, you wouldn't need to upload each custom character to the server... you could just change the character image to the specified link. And for preloading, I looked at the source code for the trial page (hope you don't mind... it's hard to resist Although most of the main code is stored in external .js files anyways, so I didn't learn many of your secrets. ) and saw how the preloading worked. Custom images could be preloaded merely by replacing the image link with the URL of the custom image, likeso:
<img onload="incrementerCompteurPrechargement();" src="http://photobucket.com/etc etc...." alt="" />
* Also, would it be possible to anchor the textbox text to the upper-left corner? It's kinda weird in the middle left. But that's just my opinion.
* More than one correct option for image spot/evidence presenting? It would make investigation making quite a bit easier, although that would probably require a significant change to the editor to make it possible. So... yeah... that's a problem....
I hope you don't think I'm being too demanding. I really like this project. I mean, finally, a working case maker! Wow.
