If you have a question about version 6, or would just like to discuss it, talk about it here. But don't forget that suggestions and requests for new features don't belong in this topic!
Main new features and improvements
- Huge performance improvements
- Reliability improvements
- User interface and usability improvements
- New: The logic system, as seen in the Ace Attorney Investigations spin-off series.
Frequently asked questions
General
When will version 6 be released?
There is no way of estimating a release date at the moment as there is still a lot of work to do. It's extremely unlikely that it will be released in 2011.
Why is AAO 6 being created from scratch?
Old versions of the web apps used very bulky and impractical code that worked in a limited amount of browsers. It was also written in a confusing way that made it difficult to add new features. Version 6 will perform better, make it easier to add new features, and will allow us to take advantage of new web standards that could improve it even further!
Will there be any updates to AAO 5 until AAO 6 is released?
There won't be any new features added. However, some bugs might be fixed.
Can I still suggest new features and report bugs?
Yes.
Will there be a beta test?
Yes. You can try it right now!
Will my current trials be compatible with AAO 6?
Yes.
Unas: The first thing I made in V6 are loading modules to convert the old files into the new format, so you have no need to worry. All old trials should work in V6.
Trial Player
Will AAO 6 have a VS animation on the bottom screen (shown before cross-examinations and rebuttals)?
There are no plans for this feature in AAO 6.
Unas: This isn't part of my plans yet, and I don't think it'll be done. I don't consider that as very important at the moment. But well, I'll see if I have time and can think of a nice way of including that.
Will the Logic feature be supported, like in AAI:ME?
Yes.
Unas: Since it was my favourite aspect of the game, I plan to include it.
Will we be able to show two sprites on screen at once, like in AAI:ME?
Yes.
Unas: Yes, and even more possibilities than that!
Will the perceive feature be supported, like in AA:AJ?
Unas: It isn't planned for V6 at the moment, but it might appear later; I've left a place in the V6 file format where perceive might be included in the future.
Will AAO 6 have courtroom scrolling animations?
Yes.
Will the tiny arrow in the bottom right corner of the dialogue box to show that the dialogue animation is complete be supported?
Unas: It should be easy to do, so I'll probably do it.
Will videos be supported?
Will talk conversation marks (i.e. the red ticks and locks) be supported?
Unas: It's in my to-do list.
Will the Chess feature be supported, like in GK2?
Will there be an animation in the life bar when the player gets a penalty or when their life recovers?
Unas: The health bar will have a small animated smooth transition effect but I'll probably not add the small "explosion" animation.
Will greyscale for flashbacks and inverted colours for Psyche-Locks be supported?
Unas: It's one thing I certainly would like to do, but I don't know if it will be possible in a way that works on all browsers by the time I release V6. Currently, only Firefox supports the technology to do so.
Trial Editor
Will AAI investigations be supported?
No. This will be postponed to a later release.
Will it be possible to use features like Logic and Psyche-Locks in the same trial?
Yes. All game mechanics can be used together.
Will AAO 6's sprite repository have AAI sprites?
Yes. Help will be needed to gather them and organise them properly.
Will the automatic pauses during flashes and shakes be removed?
Yes. However, you will still be able to use pauses, optionally.
Will making characters fade out be supported?
Yes, along with a few other similar functions.
Will making music fade out be supported?
Unas: I haven't decided yet. Perhaps.
Will there be a mechanism to prevent two collaborators from editing a trial at the same time?
Unas: Depending on performance issues, I might do exactly the opposite...
Will macros (i.e. automation of your common actions) be implemented in AAO 6?
Unas: Depends what you mean by macros. I have a few plans to automate small tasks, but I'm not sure what you're asking for.
Will an log system (to track a collaborator's edits) be supported?
Unas: It's quite likely. It depends on another feature I'm hoping to be able to integrate.
Will multiple languages for a single trial be supported?
Will foreground objects be supported?
Yes. There is support for multiple foregrounds and backgrounds at once.
Will it be possible to have multiple sound or music effects in the same frame?
Unas: It will be possible to set both a music and a sound on a frame, as separate settings. However, there should still only be only one of each.
Will changing the text's alignment (i.e. left, center, right, justify) be supported?
Unas: It shouldn't be a problem. I'll try to remember adding that.
