Sprite Correction Task Force
- Spoken languages: English, some german
Re: Sprite Correction Task Force
Kristoph number... um... 6 i think? (Holding up his glasses with his hands) is missing the start up sprite.
- Holhol
It is not.Godot Mango wrote:Kristoph number... um... 6 i think? (Holding up his glasses with his hands) is missing the start up sprite.
~Danielinhoni is the bestest friend anybody could ask for~
▬▬▬▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬▬▬▬▬▬
TKinhonipei is my soulmate ~<3
Liquid Snake wrote:Snake, did you like my sunglasses?
- Holhol
No. No start up exists.
- Meph
But is it a duplicate?
- E.D.Revolution
Umm...
If you look closely at the corner of his pinkie, his mouth is moving.
(Sue me, it's 4-4 version, but that's what I'm using in my case )
point being, it's not in the editor.
And it's on the Animations page, Meph.
http://court-records.metalgearsonic.de/ ... istoph.htm
- Jean Of mArc
- Spoken languages: English, French, Japanese
Here are the missing sprites I have noticed while making The Omniscient Game that have not yet been noted... and I have attached some of the fixed/missing sprites!
- Jake Marshall
- 3 - Needs replacing (speaking sprite)
- 10 - Bottom is cut off
- Olga Orly
- 2 - Bottom cut off
- 6 - Bottom cut off
Spoiler : Some missing images :
On Jake Marshall #10 there is no bottom part because the sprite is only used in the game on the witness stand. So they cut a bottom part out of the making because you'd never see it out of the witness stand.
- Meph
Thanks, Jean. However, adding new sprites is out of the scope of this initiative. It's a lot more complicated to add new ones, so we'll need to sort it out at a later date.
- henke37
No, it isn't? The sprites aren't named, so we don't need any localization. And the remaining part is to set the initial animation length and add a post to a list.
- Meph
Yes, but it's not that simple in all cases. There's a conventional order that sprites are listed in, so we can't just add them to be bottom of the list. Also, in some cases, we might want to replace current sprites with completely new ones.
- henke37
Again, that is just the conventional display order, it is easy to have a different display order from the internal id numbers. And replacing one thing with another is not hard at all.
- Meph
Yes, we should be able to sort it out after AAO 6 is released, which is why I don't want to add them now.
