Sprite Correction Task Force
ApolloGrimoire
Re: Sprite Correction Task Force
Post by ApolloGrimoire »
Trucy sprite number 21.
Does it have a start up animation? :?
Just played the prologue and it never appeared. :(
Case 1 - Nursing the Turnabout: Trial Former, Trial Latter
Meph
Post by Meph »
No, it has no start-up animation. :) Which prologue do you mean?
ApolloGrimoire
The prologue in my game.
Sligneris
Spoken languages: English, Polish
Post by Sligneris »
There was often problem with these having different sizes, I remember.
Bad Player
Spoken languages: American
Post by Bad Player »
But those are AAI sprites...
Sligneris
Post by Sligneris »
Yes and AAI sprites are going to be implemented with next AAO update, right? So I decided to put it here already.
Meph
Post by Meph »
Oh, I see what you're referring to. This discussion belongs in a different topic, but Unas has thought about this problem.
Sligneris
Post by Sligneris »
Meph, there's such thing as quoting... :P
Bad Player
Well, it shouldn't be such a problem in v6 because v6 supports the super-long backgrounds and scrolling, right?
Meph
Post by Meph »
Sligneris wrote:Meph, there's such thing as quoting... :P
I was responding directly to your post above mine. Why would quoting be necessary? :P
Bad Player wrote:Well, it shouldn't be such a problem in v6 because v6 supports the super-long backgrounds and scrolling, right?
Supporting super-long backgrounds is not the same thing. When a character is wider than 256px, the system will still need to position the sprite correctly. But don't worry; it does, as long as the torso of the wide sprite are still in the centre of the sprite's canvas. ;)
Sligneris
Post by Sligneris »
Meph wrote:I was responding directly to your post above mine. Why would quoting be necessary? :P
Hmh. Right. ;)
Meph wrote:Supporting super-long backgrounds is not the same thing. When a character is wider than 256px, the system will still need to position the sprite correctly. But don't worry; it does, as long as the torso of the wide sprite are still in the centre of the sprite's canvas. ;)
That's pretty much why I put here these sprites (including these on previous page). That problem is visible for example here.
Meph
Post by Meph »
But the Web platform doesn't suffer from the same issues as a video editor. :XD:
ApolloGrimoire
Some of the other sprites for Trucy are in weird positions, 23 should be the start up sprite for 21 and 2 should be the blinking sprites for that position.
To me, that's a bit confusing.
Sligneris
Post by Sligneris »
Meph wrote:But the Web platform doesn't suffer from the same issues as a video editor. :XD:
Sure. But, there is possibility that character will just move few pixels left or right, just when they finish speaking. It wouldn't look that good.
Meph
Post by Meph »
Nope. Not if the speaking and still images are kept at the same width, and the torso is kept in the same position in both canvases. :)
