[E?], [P]Characters Flying Off Desks?
Cubix
Spoken languages: English, Español
Post by Cubix »
Note: I put [E] because I'm not sure whether I did something wrong in the editor or not.
Operating System: Chrome OS
Browser: Google Chrome
Link(s): http://aceattorney.sparklin.org/player. ... 8501&debug
http://aceattorney.sparklin.org/editor. ... l_id=78501
I have not saved this trial yet, however, as I kept on testing it out to make sure it wasn't just some glitch, it turns out this is some sort of bug.
I'm currently working on a new trial, and have refreshed many times on the Trial Player to ensure that the courtroom positions weren't converted in any way. Then something else happened: Phoenix's sprite on frame 6 (after he nods his head yes) suddenly flies off of the courtroom background. I tried to make it go away in the editor, however, I'm sure I didn't do anything wrong there. When you start the trial, go to frame 6 and you'll see it happen. If you go through the trial once, redirect yourself to frame 6 and then Phoenix's sprite will dash back into the courtroom. I don't know exactly why this happens, but it's odd. Also, I'm not entirely sure whether you'll be able to access the editor for the trial.
This sig won't change unless something changes.
Re: [E?], [P]Characters Flying Off Desks?
Frame 7 and 8 : Phoenix is set at position "Centered". In the courtroom, this means the witness stand !
It should be left aligned to have him on the defense bench :)
Cubix
Post by Cubix »
Ah, thank you, Unas. I did that, and the problem was solved.
