I noticed some of my external character poses get replaced with other external character poses of the same character when I use them in the editor. For example I made a pose called Angry, but the sprite of Happy shows up instead. Going into the screen editor and changing the character sprite I see that it changes, but when i hit confirm it goes back to the incorrect pose as if the editor now thinks that Angry is Happy for some reason.
I'm on Chrome
External character poses get replaced with other poses
- Smashman64
Re: External character poses get replaced with other poses
Oh, this one. This bug was first reported back in July. I've fixed it on the developmental version of AAO, but it isn't fixed on the version of AAO that the public can access.
Save your trial, and stop working on it. Post here when you do, and I'll do the closest thing to a fix that I can.
- Smashman64
Thank you. I had changed The two poses that kept taking over and named them "xxx" and then just made two new version of the ones that were getting changed with "Actually" in front to try and counteract the problem but it doesnt seem like it will stop. Also deleting them didnt help either it just happened again. http://aceattorney.sparklin.org/editor. ... l_id=80725Enthalpy wrote:Oh, this one. This bug was first reported back in July. I've fixed it on the developmental version of AAO, but it isn't fixed on the version of AAO that the public can access.
Alright, it's fixed. You'll need to change the poses you don't want to the poses you do want, but that should be possible now.
Until the fix for this bug is on the main version of AAO, don't delete sprites unless it's the very last sprite. That risks causing this bug again.
- Smashman64
Thank you! I appreciate it. What do you mean by last sprite? Like on the bottom of the character pose list?Enthalpy wrote:Alright, it's fixed. You'll need to change the poses you don't want to the poses you do want, but that should be possible now.
Correct.
- Smashman64
Excellent! Oh sorry just one more question is it safe to rename the "xxx" poses?Enthalpy wrote:Correct.
Yes. The only thing that will cause this bug again is deleting poses that aren't the last ones on the list.
- Smashman64
Niiiice you're a God. We can be friends now right?Enthalpy wrote:Yes. The only thing that will cause this bug again is deleting poses that aren't the last ones on the list.
