Link: http://www.aaonline.fr/editor.php?trial_id=70281 (not the actual trial; I'm shy about unfinished work, but I was able to reproduce the bug elsewhere)
What happened?: I tried to edit the "ask a player to point to a location" action, and nothing popped up. I could ADD the action fine, but I was unable to edit or delete it. The dialog screen did not appear.
What did you expect to happen?: The normal popup occurring like it always does.
Can you reproduce the problem?: Yes and yes. I know for absolute certainty that, on my operating system, on my browser, it is impossible to edit or remove "Ask a player to point to a location.
What did you do before the problem showed up?: I clicked "load from runtime expression" for the background of the location. That is the only constant between the two attempts to create the bug.
I really hope this can be fixed, because my runtime expression is incorrect, but I forget what it was. Can't edit it without reaching the dialog screen!
![Gray :gray:](./images/smilies/aa_icon_gray.gif)
UPDATE: Bug was also encountered in Chrome 61, and in my Windows 7 virtual machine. It was not encountered unless the background was loaded from a runtime expression.
