You said: "Psyche-lock on Andrews happened off screen? Any reason why we didn't get to see that?"
It's because the facts of the case are always told in court and I didn't want to be repetitive. That and all Case 1's in canon take place entirely in court. It's not like you didn't get to see any Psyche-Locks, right?
You said: "People change Maya, it's called "life experience", don't be so naive."
Except Pearl barely changed at all while Maya was there and suddenly she's completely different shortly after she left.
You said: "The timed frames on the Objections and Hold Its are a bit long, 100 is the normal setting isn't it?"
I always thought 200 was the correct timing. It's closer to the length in canon.
You said: "Have a bug here, when I choose the second page to examine of the guide it shows the first page."
Thanks for catching that. I'll edit the case accordingly.
You said: "Found a Team Fortress 2 Engineer quote. Spoken by Payne of all people. And after that the Scout."
And after that the Spy.
You said: "Would you like a numbered score?"
Sure, why not?
Sure, why not?
