How to make a good Pursuit theme?
Discuss topics that are unrelated to Ace Attorney Online, introduce yourself if you're new and read the latest Member of the Month interview.
Règles du forum
Message par UltrawaveStudios » Mer Juin 08, 2016 10:14 pm
I have no idea where to write this topic, so I'm doing it here.
I'm making a Pursuit theme for my fangame which I'm somehow still doing.
Here's what I have: https://soundcloud.com/ultrawave-studios/a-pursuit-theme-with-potential
There are some problems with it. One of the most obvious being that there are parts which sound more like an Announce the Truth theme than a Pursuit theme, which is definitely something I don't want.
Could I get some tips on this? Thanks.
JUNE 30: https://soundcloud.com/ultrawave-studio ... suit-theme
BETTER: https://drive.google.com/open?id=0B1Ac_ ... kFERi0tOWs
UltrawaveStudios
Message(s) : 140
Langues parlées: Anglais, s'il-vous-plait.
Re: How to make a good Pursuit theme?
Message par DeeYo » Mer Juin 08, 2016 11:12 pm
The tempo's too low. The chord progression doesn't feel triumphant at all, usually achieved by putting a lot of major chords inside an otherwise minor song. The introduction has no bass and no chord, only that steampunk, unfitting instrument and drums (are you sure the instrument playing the melody there isn't normally a bass instrument?). The square lead from 0:05 seems to play in a wholly different key. The violin feels obviously fake and doesn't fit the rest of the GBA-era instruments. Crashes too close to each other are bad practice. The violin at 0:52 plays the note one semitone lower than the main note - very dissonant. The drums shouldn't stop at 1:04 - in a pursuit theme, the player should, at all times, feel pumped. It's somewhat hard to hear where measures begin - try marking the 1sh and 3nd beat of every measure with a kick. The key change at 1:14 is strange. The bells at 1:25 are very dissonant.
Try listening to a lot of Pursuit themes and remake the track from scratch - I don't believe this can be salvaged.
Total times sued: 10328
DeeYo
Message(s) : 936
Langues parlées: Hungarian, English, some Russian, Spanish, German
Message par UltrawaveStudios » Jeu Juin 09, 2016 12:57 am
Alright then. Thanks a bunch!
By the way, for that song, the tempo is set to 180 bpm. However, with other Pursuit themes, I'm finding them within the 120-170 bpm range, unless I'm counting things wrong.
Raison : Please do not double post.
UltrawaveStudios
Message(s) : 140
Message par DeeYo » Jeu Juin 09, 2016 12:34 pm
UltrawaveStudios a écrit :By the way, for that song, the tempo is set to 180 bpm. However, with other Pursuit themes, I'm finding them within the 120-170 bpm range, unless I'm counting things wrong.
The problem with setting songs to 180 BPM and then only putting snare drums on the 3rd bar of every measure instead of the 2nd and 4th is that it will sound as if it was in half-time, at around 90 BPM.
DeeYo
Message(s) : 936
Message par 123fendas » Sam Juin 11, 2016 8:33 pm
On an unrelated note, the Pursuit theme you've made is REALLY good! Image
(Yes, that's a failed a-ok emoji I made.)
eastmost peninsula is the secret hello there would you mind taking a survey: http://www.strawpoll.me/14950090
123fendas
Message(s) : 234
Langues parlées: Svenska, English
Message par UltrawaveStudios » Jeu Juin 30, 2016 10:53 pm
I'm back, and I still need help >~<
And a maybe-maybe not better version as of 7:23 PM EST
UltrawaveStudios
Message(s) : 140
Message par DeeYo » Ven Juil 01, 2016 4:52 pm
Much better.
Still, the chord progression for the most part is Am-G-F#dim-G. F#dim is a pretty bad choice as it's a diminished chord, which is completely against the fact that Pursuit themes are supposed to make you feel confident. It's also a bad choice because you don't seem to know about diatonic scales and keep throwing in random notes, and the notes F and G both conflict with the F#dim chord.
You're also lacking a strong, memorable melody (I'm sure you didn't plan your melody from 0:32 onward), to the point where the whole song from there feels like a solo.
My advice is to study diatonic scales. Don't just use whatever notes you like - know what tonic, subdominant and dominant is, how they lead into each other, what chords they correspond to in which keys. (Case in point: the first note in your melody at 0:07 is a B. The Am chord is composed of an A, a C and an E. It's usually worthwhile to select one of these three notes, especially when the note is long.)
DeeYo
Message(s) : 936
Message par UltrawaveStudios » Sam Juil 02, 2016 2:03 am
Do you happen to have FL Studio and would like to help me out with this? I can send you the midi and the soundfonts I used.
UltrawaveStudios
Message(s) : 140
Message par DeeYo » Dim Juil 03, 2016 9:55 pm
I'm afraid I can't help you - the old adage "too many cooks spoil the broth" is valid for composing as well. As the track is flawed from the get-go (see my comments about the F#dim chord in the last post), I can't really fix it with minor adjustments, and if I rewrote it completely, that'd be my track, not yours.
I suggest you study diatonic scales and don't really use other notes until you're sure of what you're doing. For example, only use the notes A, B, C, D, E, F, G and G# if you're composing in A minor. Of course, you aren't *bound* to these notes, but using too many other notes lead to your melodies becoming hard to memorize and/or dissonant.
You should also study Pursuit themes and examine how they're built up.
DeeYo
Message(s) : 936
Message par da_racer64 » Mer Fév 15, 2017 4:30 pm
I wouldn't mind helping. I'm making a fangame myself. Maybe we could help each other out. :)
Sorry, Must Dash.
da_racer64
Message(s) : 11
Langues parlées: English, Learning Spanish.
Retour vers General chatting
