I would like urgent help to fix my computer.
Discuss topics that are unrelated to Ace Attorney Online, introduce yourself if you're new and read the latest Member of the Month interview.
Dramatica
Post by Dramatica »
Yes, I'm getting desperate now.
What's up?
If you've seen my post in the rant topic, you should know. Anyway, I'll sum it up here.
A while ago, probably a few months, my computer started freezing. Randomly. I had to turn it off from the power button. Sometimes, this would happen 3 times a day. Now that I've mentioned that, something completely different.
When my sister came home, the computer shut down on start up. By shut down, I mean it would turn off. Without warning. Just turn off, no 'shutting down' screen or anything. But it was alright, it would just happen on start up. Once.
It got worse.
It would happen a few times on start up. Still not much. It got worse yet.
By this time, my sister had left. It would take 10 times AT THE LEAST to get it working, and THEN there was no guarantee it would stay on. It ended up being impossible to use, basically.
Then we discovered safe mode. It looked ugly, and THERE WAS A CERTAIN OTHER PROBLEM I WON'T MENTION BECAUSE I MIGHT KNOCK DOWN ANOTHER WALL. But it worked. Then, today... It got worse and will get worse. It started shutting down randomly in safe mode. Not as often as normal, but still. And how will it get worse again? My sisters coming home again in the next week. Oh, and she miiight need sound because she's becoming a DJ and needs to be putting together a playlist.
What are you posting this for?
I need your help. I'm getting desperate.
Okaay... Why did you post a new topic for this?
I wanted the most attention I could get. I couldn't think of anywhere else to post it anyway.
Why don't you just call the EBA or whatever it's called?
They don't exist.
You know, you're-
Thanks, but on topic.
Why don't you do it yourself? What have you tried?
  • Doing a virus scan. I found one item, but it's gone now.
  • Checking out the sockets. One plug was a bit loose, but after fixing it, it still didn't work.
  • Disabling all the unnecessary startup items. It's not a problem with startup anyway, as it isn't always doing it on startup.
  • Holding a tally of how many times it shuts down up the the computer monitor so it realised what a bad boy he is.
  • Drawing a picture to take my rage out on who [censored] sound [censored] mode.
If I can't suggest ideas to fix it like you want me to, what else can I do?
  • Stop my cat's fur from coming off. I'm not sure of the term, but Wikipedia (ang Google) has a really bloody scary picture of what I thought it was.
  • Convince iNiS to hurry up with/make EBA2.
What's in it for me?
  • My presence and happiness.
  • An official Drammy™ goody bag.
  • Eternal thanks.
...so yeah. Can anyone help?
Meph
Re: Teh Quest of Repairocity (i.e. helpplz)
Post by Meph »
It's most likely an internal hardware problem. The likely outcome of this problem is that you'll need to buy a new computer.
Anyway, take out everything from your computer except the monitor. Then see if you don't have any problems.
Also, answer these two questions:
Is it a laptop or a desktop?
What is your operating system?
If it's a desktop, open the chassis (a.k.a. the tower, the brain, the case, etc) and remove all dust. You must regularly remove dust from your computer every 12 months (but I recommend every six months).
It's very unlikely that the operating system is causing this problem. The operating system is switching itself off for a very good reason: to protect you from the computer bursting into flames or overheating or something.
Dramatica
Post by Dramatica »
I shall do that. If I can...
It's a desktop, and Vista.
Meph
Post by Meph »
DramaticaXIV2 wrote:I shall do that. If I can...
Vista is not the cause of the problem. However, have you tried using Windows Update? Make sure that you install optional updates as well.
Dramatica
Re: I would like urgent help to fix my computer.
Post by Dramatica »
By now, I'm pretty sure it's a physical problem with the computer... but it still seems unlikely, thinking about it...
Anyway, I'll be having someone looking at it. I'll still do what I can.
Meph
Post by Meph »
Yes. Proffessional help is the best help you can get. It might be a problem with the power supply.
General Faust
Post by General Faust »
I had this problem with my old com what you should do is crack the computor open and tkae out your memory drive and clean it. Do this with all of the components. But Just in case, before you clean meke sure you ssave all the things you want on a back up file
TEAM FORTRESS
EmaTheScienceSkye
Winner of AC 1#!
Spoken languages: English, Chinese, French, Spanish, Japanese
Post by EmaTheScienceSkye »
When does it shut down? Does it get past POST? Does it get to the Windows loading bar screen?
Your Resident Ema Skye Impersonator.
Blah.
PhantomH
Post by PhantomH »
I would also like to know when it shuts down as well. On a side note, it could be a hardware failure. Try using a different HDD and see if it still shuts down. If it still does, try replacing the power supply.
No Dine. No Knox. No Fair.
Meph
Post by Meph »
PhantomH wrote:Try using a different HDD and see if it still shuts down. If it still does, try replacing the power supply.
That's easier said than done.
EmaTheScienceSkye
Winner of AC 1#!
If it turns out that the power supply is Apevia or Rosewill or something, I bet it's that. If it gets to the Window's loading screen, it's a virus. If the computer beeps, it's probably a hardware issue.
Blah.
Meph
Post by Meph »
EmaTheScienceSkye wrote:If the computer beeps, it's probably a hardware issue.
Some computers beep anyway when you turn them on at the mains.
