What would be legitimate reason for a train to shake hard?
- Chapa
- Spoken languages: English, Filipino
I want to know why a train would shake so hard causing the passenger to trip and fall? Or their belongings to spill out? I need a legit answer. Thanks!
Re: What would be legitimate reason for a train to shake har
Wrong section. This section is for questions about using the editor. You should direct your comments/questions to either your own trial thread, or ask in say, the ToR in General Chat. Meph can move this thread for you.
As for your question... well, I guess that if the driver had to break suddenly (perhaps a bridge had broken, or there had been signal failure and they were about to collide into another train), the passengers might trip and fall. There's also the possibility of an earthquake...
- Meph
Whoops. Sorry. I misread your PM when you asked me where you should ask me this question, Chapa.
Moved to General Discussions.
I can only think of one way
It would be an emergency brake launched by anyone, most of the trains don't shake when they do that but some may produce a huge shake when they are activated
No legit sources except me, I was in a train which had its emergency brakes activated
- Meph
It would also depend on the design of the train. The design of the trains here in the UK are a bit odd, because we have the oldest rail network in the world, so trains have to be optimised for lower speeds, smaller stations and short carriages.
However, you could still trip over when the train comes to a stop at a station and you're not holding onto anything.
- Chapa
Hmm... The emergency breaks are a good reason to go with. I'd go with the signal failure, wherein the trains are about to collide with each other. Earthquakes, as suggested by Tap, will do as well, since it is a fan-game after all. Thank you, everyone! (Woah. I just noticed that the three of you are Mods...)
- Spoken languages: English, some german
Otherwise, it could be just simply going over a hilly land.
My brother was on a train once, he said it started shaking as they went over some hills.
- Reyson
It could also actually collide with another...
Rey Rey the Jet Plane
- Stealthfire
How about a track fault, like the track became bent somehow? The train might go too fast over a fault in the track almost, but not, derailing. It would probably make it shake. It usually depends on how heavy the train is though. fast and heavy trains (most modern trains effectively) will probably just run straight through. Old trains would be more easy to rock about. Same goes with tracks actually. If just need an excuse, you could say the tracks are worn out etc. If you want something exciting, then you could go with the train almost colliding with another. It's up to what you want.
Eshvelut Lochelle, king.
Roxciel Artefille, the world's librarian.
Salfira Artefille, madhatter. lulz.
My characters of Endless Time.
I failed! Dood!
Anyway, try counting the words. Lines are too big I find.
... ...僕は少女じゃない!
I have a HHNNNGGG!! worthy sig now. Click it!
I failed! Dood!
... ...僕は少女じゃない!
