I've 2 questions about the usage of sprites.
1. How do I use custom sprites? According to this thread: http://aceattorney.sparklin.org/forum/v ... =28&t=2155, I have to add the sprite image links. However, I don't see anything in the editor that allows me to do just that.
2. How do I add a sprite such that (s)he appears to be behind the glass panel in the Detention Center? I can only add sprites that appear in front of the glass panel but that's not what I want.
Any help is appreciated. Thank you!
Sprite question
- Spoken languages: English, Mandarin
- energizerspark
Re: Sprite question
there are two versions of the detention center background (not to be confused with the AA and AJ versions)
if the version you have selected has the characters in front of the panel, select the other version
Re: Sprite question
As for your first question, if you want to use custom pictures for a profile, might I suggest you create a profile in the editor and click the "use custom pictures" button on that profile?
Re: Sprite question
Yeah, I've already done that. What I want to know is how I display a custom sprite in a particular frame.Enthalpy wrote:As for your first question, if you want to use custom pictures for a profile, might I suggest you create a profile in the editor and click the "use custom pictures" button on that profile?
For example, I want to use an Athena sprite that I've downloaded in this frame. However, I'm not sure how to do that.
Edit: I've figured it out. Thanks nonetheless!
- foursideluigi
Re: Sprite question
If YOU've figured it out, do you think you could help ME?
I have a full sheet of sprites for Apollo I want to use, but I don't know how to: A: separate the backgrounds from them, and B: seperate them in general. Could I get some assistance?
Re: Sprite question
That is a completely different question.
First, are you sure you want to use a spritesheet? The canon Apollo sprites are already in the editor.
If you're absolutely sure you need to use the spritesheet, I recommend requesting somebody on the request topic or asking a question here.
