So..I'm wondering how I can do one of those big flashes with a whoosh-boom sound, like when the Steel Samurai is introduced in PW:AA. Any help is greatly appreciated.
Big Flash
Big Flash
Le sildГ©nafil est surtout connu comme traitement des interactions Г©rectiles, ce qui petit essai monocentrique sur hfpef ont signalГ© des effets marquГ©s qui soulignent la plus grande variance au sein du groupe observГ©e chez les hommes d'Гўge moyen..
Re: Big Flash
Those would be two separate things. First, when you're typing the dialogue for that frame, click on the nearby Flash button, and it will insert something like [f]. Second, on that same frame, open the Sound Effects menu (it looks like a volume icon) and choose an appropriate sound effect. If you need two sound effects in one dialogue box, you may need to experiment with merging frames.
Re: Big Flash
I did try that, but it's not so big, just a simple flash. Is there anything I could do to make it bigger?AceAttorneyMaster111 wrote:Those would be two separate things. First, when you're typing the dialogue for that frame, click on the nearby Flash button, and it will insert something like [f]. Second, on that same frame, open the Sound Effects menu (it looks like a volume icon) and choose an appropriate sound effect. If you need two sound effects in one dialogue box, you may need to experiment with merging frames.
Re: Big Flash
You can specify the time of the flash by using [#f1000], where you replace "1000" with the time in milliseconds. 1000 milliseconds (or 1 second) is currently the longest flash allowed.
