Recommended frames
Super legenda
Recommended frames
Post by Super legenda »
What amount of frames is good for my first trial?
AceAttorneyMaster111
Re: Recommended frames
There's not a specific amount. Does your trial flow naturally? Does the dialogue make sense? Is the logic correct? Is it fun to play?
If you really want an amount, here's a quote from E.D. Revolution's AAO's Truly Comprehensive Guide for New Authors:
E.D. Revolution wrote:We recommend that your first trial-only case that runs at least 2000 frames TOTAL. Anything less than 1250 frames (including game over sequences) tends to fall on the short side. If you do this correctly, you should be able to fit around 4-8 cross examination blocks in there. If you have 13 cross examination sequences in 300 frames, however, you're doing something wrong.
Super legenda
AceAttorneyMaster111 wrote:There's not a specific amount. Does your trial flow naturally? Does the dialogue make sense? Is the logic correct? Is it fun to play?
Thanks! I go to do a trial, after a investigation, and other trial. 2000 frames between the two or each trial have 2000?
Super legenda
What amount of frames in a case is ok for 2 investigations and 2 trials?
Again, I'd say don't worry about the frame count. Does the stuff in the investigation make sense? Is it free of bugs? Is the evidence or the progress rushed? Is it fun to play? Think about questions like these, rather than how many frames you have.
Super legenda
AceAttorneyMaster111 wrote:Again, I'd say don't worry about the frame count. Does the stuff in the investigation make sense? Is it free of bugs? Is the evidence or the progress rushed? Is it fun to play? Think about questions like these, rather than how many frames you have.
Ok, i ask because i want a good length.
I would request for playtesters in this topic. They'll tell you if it should be longer.
Last edited by AceAttorneyMaster111 on Sun Sep 24, 2017 12:20 am, edited 3 times in total.
Super legenda
AceAttorneyMaster111 wrote:I would request for playtesters in [link=http://www.aaonline.fr/forum/viewtopic.php?f=15&t=10206]this topic[/link]. They'll tell you if it should be longer.
Thanks!
