Okay, I'm not sure if this is the right place to post it but I have an issue. You see, the music looping on AAO online makes it so that a lot of songs miss some of the last beats 'cause then they start over again instead of looping like the games did. It can also ruin the excitement of the theme, mainly with the objection themes as after it's done it just goes back to the start which ruins the flow and momentum of the piece in my opinion. So I was just asking if there was any way for the music to loop properly and if not, then is it possible to be included later on?
I hope this made sense.
Music looping
Re: Music looping
This would likely need to be done manually, I'm afraid. If this is a big enough issue for you, you'll have to upload your own tracks with the ends cropped off.
