I`ve read through some of the guides regarding variables, but don`t seem to get it to work in my trial-at-works.
Specifically, I need help with a cross-examination where the player will need to press all the statements. Once that`s done, the game will proceed and allows the player to exit the cross-examination.
I tried doing the variables on each statement ( 5 in total ) according to The Common Way, as introduced in this guide: viewtopic.php?f=61&t=9514 , under the "Press-all-to-continue" segment.
I don`t know what am I doing wrong, here`re some screencaps from the CE in question:
I did this at the first statement of each press convo, when the defense yells "Hold it!", except that on latter convos of the same CE, the "press1" changes into "press2", "press3" and so on, corresponding to the number of where in the CE the statement and convo is located. 1 for the first convo, 2 for second and so on:
Large picture:
Also, the failure frame is outside the CE, is that done correctly or wrong?
Large picture:
