How do I change a character's sprite while they're talking?
Bitter_Godot
Post by Bitter_Godot »
I've seen many turnabouts just like the ones in the AA games that the characters expression changes even in the same frame. Like, for example:
Phoenix is reading a paper: The autopsy report clearly states the opposite of what you just said, Ms. Pujols! *Phoenix changes to his index finger pointing sprite* What can you tell us about this, "Ms. Pujols"?!
[url=http://www.mgstruefans.com/forum/showthread.php?tid=663
Image[/url]
^Click to read my Solidus Snake/George Sears fanfic^
Re: Changing Sprites
You have to merge two texts, using the "Merge with next" button.
In the first, you select the first sprite and the part of the sentence to which it corresponds, and in the next one you put the second sprite and the corresponding sentence.
You can do that with more than 2 texts, by the way.
Hodou Okappa
Post by Hodou Okappa »
Of course, in the real game, they'll frequently do things that would require several Merges and f#/s# commands in one sentence. So it can get pretty tiring. :shock:
Also known as: okappa, houdou.
henke37
Spoken languages: Swedish,English
Post by henke37 »
For the silly things that the game does, look at the phone throw.
Hodou Okappa
Re: How do I change a character's sprite while they're talking?
..Phone throw...?
Whikebain
Post by Whikebain »
Last case of JFA, remember. Day 2 i believe
Phoenix to Edgeworth
Bitter_Godot
YAY!!! Thanks everyone! Also, how do I add the "Check" button to a piece of evidence like the autopsy report?
Image[/url]
Meph
Post by Meph »
Look at where it says "Data for the Check button :" then press "add". ;)
