How can I fix my animated picture?
For my trial I created that animated picture:
At some point in the game a character should type a password in. The problem is that all pictures are loaded in the beginning of the trial, right? So the animated picture started before it appears in the game. When I take this infinite loop version it's left to chance at which moment the player sees the picture. When I take the version, wich plays the animation only one time it's alredy finished when the player sees it.
So what should I do? Is there a feature I didn't saw? Or a trick?
P.S. I am german.
"All hail Unas, the omnipotent!"
Copy this into your signature to help Unas on his way to world domination!
- Meph
Re: Problem with animated picture
Unas will fix the problem soon. This has been discussed loads of times.
Also, you're image should be 256px x 192px.
- henke37
Btw, there will eventually be an action for interactive text input. Let's hope that it has password support.
Okay.
(Please fix it until the 15th June, Unas, this trial is for the May/June competition ^_^')
Thanks for remembering (and for replying of course), Meph
Edit:
Go Unas, go Unas!
Oh, almost forgot that this is the wrong version.Meph wrote:Also, you're image should be 256px x 192px.
Edit:
That would be great!henke37 wrote:Btw, there will eventually be an action for interactive text input. Let's hope that it has password support.
Go Unas, go Unas!
P.S. I am german.
- henke37
It's already promised, just wait for unas to implement it. He might do it fast. Or not. He didn't say anything about that.
Will I ?Meph wrote:Unas will fix the problem soon.
I mean, I've already used my trick to restart a gif for characters one-time animations support, but I didn't think I would restart every gif on display, as it didn't seem necessary, and possibly cpu resource consuming.
But you are right to ask me that now, it should be very easy to do - considering most of it is already implemented - and performances shouldn't be too much of a problem. I'll run a few tests to be sure, but it should be okay.
You are lucky it seems easy to do, because I won't have much time until 15th JuneFarawyn wrote:(Please fix it until the 15th June, Unas, this trial is for the May/June competition ^_^')
I'm studying hard again, now that my written tests are over, preparing for the oral tests that will take place for me between June 20th and July 19th.
Well, actually making the suggestion is more efficient than hoping, because I'd never have thought about that spontaneouslyhenke37 wrote:Btw, there will eventually be an action for interactive text input. Let's hope that it has password support.
Anyway, the keyword here is "eventually"
You can never know in advance when I'll be motivated enough to do it. As soon as I decide to do it seriously, it's fast, but since I'm already studying seriously aside from that and can't do two simultaneous things as seriously...
- henke37
With a proper layering system, it would be much easier to get everything right.
Or you could just add yet another hack to run the effect from the start to the end, over everything else. Like the gavel smash. Seriously, that needs the run once system too!
Edit: Ops, I seem to have been a bit sidetracked, I was mainly thinking of those pans, but it applies none the less here as well.
- Meph
Yes, now do as I sayUnas wrote:Will I ?Meph wrote:Unas will fix the problem soon.
- Bad Player
- Spoken languages: American
Uh... Could you tell us about that tric, please? ^^'Unas wrote:Will I ?Meph wrote:Unas will fix the problem soon.
You can't use it in the editor, it's just a technical way of restarting gifs even though Javascript doesn't normally have functions for this. I programmed the game to use it on some sprites that require one-time animations (such as Phoenix raising his arm for an objection, etc), but you can't trigger it yourself, it's automatic
- henke37
It's probably easier if you just read the source code. Oh, wait, it's in French. Besides, it's always a pain to hunt for stuff in other's code. You better just wait for Unas's reply.
Well, if you want technical details, it's just that Firefox restarts a gif animation in the whole page when this file is loaded into a JS Image object.
So I have a JS Image object (for henke : it's named "redemarreur_d_anim" in the source code, which means "anim_restarter") that I use only for restarting gifs : each time I need to display a one-time animation, i load this animation in the object before (by "redemarreur_d_anim.src=" the picture's url), and it's restarted.
I can easily program the game to do that on every animation too, I'll have a look.
- Bad Player
If you do that, will it do that for all animations (including customs) or just the ones already loaded into AAO?
- henke37
Well, I can't say that I can think of any case where I wouldn't want this. Only cases where it wouldn't matter to begin with.
Re: How can I fix my animated picture?
All animations - including custom ones - will be restarted on display.bad player wrote:If you do that, will it do that for all animations (including customs) or just the ones already loaded into AAO?
As henke said, I don't think anyone could complain about this
