What SAFE sites can I use to host music (except fileden)?
- Ami
Okay, so I'm trying to add external music, but 4shared doesn't have links that end in ".mp3". Fileden is quarantined by my security software, so I can't access material. So I need to find a (secure) file storage site in which I can gain appropriate links to use in my trial maker.
since 2008!
- Meph
Re: Which sites (which are safe) provide...
This is a tough one. Maybe you could make a Webs account at www.webs.com and put the files there. But it'll most likely be deleted.
- Ami
Why would it get deleted?Meph wrote:This is a tough one. Maybe you could make a Webs account at http://www.webs.com and put the files there. But it'll most likely be deleted.
since 2008!
- Meph
Because it's a site for websites, not for file hosting.
- Ami
Any other ideas other than stuff that doesn't end in deletion? Otherwise, I'm sorta hoping the next revision isn't as picky.Meph wrote:Because it's a site for websites, not for file hosting.
since 2008!
- Transfinite
If you can't find anything else I could host the files for you. Put them on Sendspace or something and send me the links.
- Meph
Re: What SAFE sites can I use to host music (except fileden)?
I've got an idea! You could upload them to ZetaBoards via the ACP!
It's true that except fileden, few file hosts give direct file links... http://www.hotlinkfiles.com/ should do that too. If it doesn't work for you either, I'll look a bit more into it
EDIT : http://www.mydatanest.com/ looks rather better than hotlinkfiles, you can have a look too
- Ami
I just saw this... THANK YOU! ^_^Unas wrote:It's true that except fileden, few file hosts give direct file links... http://www.hotlinkfiles.com/ should do that too. If it doesn't work for you either, I'll look a bit more into it
since 2008!
- Thatonejimmy
Another good one is https://instaud.io/ and, another pro, It's still a working website, unlike the other two.
Here's My sprite thread: http://www.forums.court-records.net/vie ... 12&t=31222
Sadly though, it doesn't seem to allow hotlinking, which is very much needed for putting music in a case.
- Thatonejimmy
Actually, Just right click the download link, and copy the link. It worked in my trial.
- Spoken languages: Svenska, English
Dropbox works for me just click on the "Share" button and copy the link. If you don't click "Share", it won't work because then the sound will be private.
This is a very old topic, but if you want music, try kiwi6. Their issue was fixed, and my files work. It's also free!
- Lind
- Trustworthy Spriter
- Spoken languages: Yes.
Kiwi6 is no longer allowing uploads for anything but premium users.
