How do character's fade in?
MrJetz
Post by MrJetz »
I have seen it in other cases that the character fades in into screen.. Is this possible or is just me seeing things...
If it is how do I go around doing so? is there a fade-out option? & can the time it takes to fade be adjusted?
Help with this will be very appreciated,
Thanks! :)
henke37
Spoken languages: Swedish,English
Re: Fade-In Character
Post by henke37 »
It is automatically done in some situations. If you ask me, it's rather inconsistent. You can not directly control it, you can not do any away fading and you can not control the timing.
MrJetz
Post by MrJetz »
henke37 wrote:It is automatically done in some situations. If you ask me, it's rather inconsistent. You can not directly control it, you can not do any away fading and you can not control the timing.
Oh I see... Well, I guess until is this is fixed I will have the animation myself.
Thanks for letting me know! :D
Characters fade in automatically when the displayed character changes but the background remains the same. Therefore, as long as you remain in the same scene (same bg), it should all work by itself ;-)
MrJetz
Post by MrJetz »
Unas wrote:Characters fade in automatically when the displayed character changes but the background remains the same. Therefore, as long as you remain in the same scene (same bg), it should all work by itself ;-)
That's weird.. cause it did not work when I did this.
Can you give me a link to the trial in question, so that I can have a look ?
MrJetz
Post by MrJetz »
Unas wrote:Can you give me a link to the trial in question, so that I can have a look ?
The link that your asking would be this
http://aceattorney.sparklin.org/jeu.php?id_proces=9519
EDIT:
I Found out how to do this after experimenting with the trial manager for a while. I do see that the fade-in feature randomly works so you can't really rely on it much...
This part after the Intro ( Just type "skip" to go to the area in question, this is when Phoenix Wright first appears on screen )
shadowthewolfaj
Re: How do character's fade in?
Post by shadowthewolfaj »
Hi, it's been 10 years, did anything change... I'm new to the site and I'm stuck on this
Can you elaborate on what exactly you're "stuck on"?
