How do I make players collect evidence before advancing?
How exactly do I make so that the player won't advance until some pieces of evidence are found? For example, if a player needs to find piece A and piece B he won't advance in the story (skip to a certain block) until both are in the court record regardless of the order in wich they were found. This probably has something to do with variables but I don't know anything beyond that.
- Meph
Re: Coming up: The Plot
Variables are needed for that. However, I'm not very good with variables.
- henke37
You can actually get away with only expressions, since it is possible to query what evidence is revealed in one.
f:evidence_is_revealed("preuve",1) & f:evidence_is_revealed("preuve",2)
I don't think everyone will understand it if you use the same word. And if I'm right, you mean that I replace the "preuve" with the evidence name?henke37 wrote:You can actually get away with only expressions, since it is possible to query what evidence is revealed in one.Code: Select all
Re: How do I make players collect evidence before advancing?
No. "preuve" is how the editor knows you want a piece of evidence, rather than a profile. The editor knows which piece of evidence you mean by the number, the evidence's ID.
If this worked off of evidence name, what if you needed to update evidence without changing its name? The game engine can't know which "Autopsy Report" you're talking about.
Actually I just found it out right after trying this out. Sorry for the inconvenience...
Need help with this, too. The code above doesn't work, all other tutorials/guides are either outdated or their links don't work.
- Spoken languages: Svenska, English
Whatcha talkin bout, Willis? I have a video tutorial on YouTube which is not outdated.punnypunypony wrote:all other tutorials/guides are either outdated
Can you show me exactly what you tried?punnypunypony wrote:Need help with this, too. The code above doesn't work, all other tutorials/guides are either outdated or their links don't work.
