Where can my sprites be hosted?
- Clover10123
Couple questions about sprites.
I want to know if you can use this site to host/upload our custom sprites so they can be used in the trials we make.
If so, how? ._.
And if you can't, then can anyone recommend some hosting sites that could host an animated gif image for FREE without resizing it or anything?
Thanks<3
If so, how? ._.
Thanks<3
Luv Clo
Re: Animated sprites...
You can't use this site, because that's hotlinking ^_^
There are several sites that will allow you to upload for free. Try imageshack, photobucket and tinypic.
- Lind
- Trustworthy Spriter
- Spoken languages: Yes.
I'd recommend Imgur. Pretty much the ideal site for multiple uploads, no resizing, and easily accessible and categorized folders.
Wrong. Don't use Tinypic for .gifs, as it will screw them up.Whirlwind wrote:You can't use this site, because that's hotlinking ^_^
- Clover10123
Thanks guys. I managed to get a hosting site...
~feels like a noob. :C~
But, like, how do you get the custom sprites to work for the character?
Like, I uploaded a standing sprite for my Bella character, but when I went back to the script, the sprite didn't show up. :C
Luv Clo
Luv Clo
Luv Clo
Ah. That's because when you use a custom sprite, you have to put it in your script before you save, or else it'll get wiped from memory.
No...?Whirlwind wrote:Ah. That's because when you use a custom sprite, you have to put it in your script before you save, or else it'll get wiped from memory.
The custom sprites don't follow the same rules as music and sound effect selections. They'll still be there even if you didn't use it and then saved the trial.
Clover: Have you made sure that the URL of your image is correct? If it isn't ending in {.gif} or {.png} then it might not work. Remember to set custom sprites for both speaking and blinking.
Moved to Help and Tutorials/Support Questions as this is more appropriate in those forums~
- Clover10123
Well, like, when I click "profiles" and I upload the standing sprite for Bella, the image turned out fine.
Then I wanted to put that sprite on the script, but it didn't work for some reason.
Luv Clo
Luv Clo
Luv Clo
... That's what happens when I use them.... O.o
- Spoken languages: English, some german
Re: Where can my sprites be hosted?
Do they have talking sprites?
- Dypo deLina
- Spoken languages: English, Dutch, German, French, Spanish, Al Bhed
Now you're the one who's got it wrong.Tap wrote:No...?Whirlwind wrote:Ah. That's because when you use a custom sprite, you have to put it in your script before you save, or else it'll get wiped from memory.
Music and SFX will disappear, whereas sprites won't. ^^'
チラセ・マギタ
~Married to Evolina deLuna~ <3
~Loving father to ZetaAzuel~
Proud creator of Cynder Janice, Rex Gladiorum, and Raimpius in Endless Time.
Why do you keep aiming to pick at the wording of my posts, Dypo? It's like you have some sort of grudge against me lately...
It makes perfect sense... what you explained is exactly what I stated.
The custom sprites don't follow the same rules as music and sound effect selections. They'll [sprites] still be there even if you didn't use it and then saved the trial.
- Dypo deLina
Tap wrote:Why do you keep aiming to pick at the wording of my posts, Dypo? It's like you have some sort of grudge against me lately...
It makes perfect sense... what you explained is exactly what I stated.The custom sprites don't follow the same rules as music and sound effect selections. They'll [sprites] still be there even if you didn't use it and then saved the trial.
Hmm, for some reason I was under the impression that the word 'don't' was excluded. ^^' I'm getting blinder and blinder lately.
And um, no... I can't even think of a reason why I'd have a grudge...
チラセ・マギタ
