Here, I have created Gyakuten Saiban 5's evidence frame. Feel free to use it.
Rule - Tell me if you are going to use it. Off course, there's no credits needed.
How to use it - After you have download the frame, use "Paint" or any other things to open it. Then, cut the things you want to put it into the frame. Lastly, colour it. Easy right?
This looks slightly misleading, it seems like you downsized a screenshot of the frame to fit the dimensions of DS-era frames, then slimmed the borders accordingly?
If i recall, the author doesn't have to limit themselves to 75x75 on the aao editor when using custom mugshots. Wouldn't it be better to retain the thick borders that GS5 uses instead? Could be wrong though.
Then again, was never a fan of the simplicity of these frames to begin with so gj replicating this for DS-era at least
I think you misunderstand ED, even if the numbers are wrong, I thought the AAO editor allows mugshots to be bigger than the minimum dimensions (which is 70 x 70)
