It's a good start but here is a bit of advice. It's definitely on the way to becoming a fantastic box-art though.
Make sure all art is scaled down to the same size as the other characters. At the moment, all of the characters are of different sizes. Klavier is extremely disproportionate since it looks like you just tried to resize his width instead of both the heightand width.
Edit the Hue/Saturation. Lamiroir looks very "dull" since you probably took her from a page of the art book. This can be easily fixed though. If you're a Photoshop user, editing the Exposure also helps. =)
Personal Suggestion: Don't limit yourself to the "normal" pose for the other characters. Try to spice it up. It doesn't look very original at the moment.
Try to use HQ rips. Some of the art looks a bit odd. Also, try and make sure that the {Scale} feature produces the best possible results. The default settings will provide an OK resize but it's better if you fiddle around with it until it's perfect.
Personal Suggestion: Change the colour of the gradient. The light blue at the topic is very similar to the {#0000FF} hex colour. The opposite and "darker" blue on the other side of the spectrum is too big of a contrast. Make sure that the gradients blends smootly from light to dark.
Your box art will help in setting the mood of your game. Since The Heartbreaking Turnabout (from my perspective) relies heavily on emotional bonds, you need to convey that with your colour choices, art and design.
More sprites uploaded concerning Lamiroir/Thalassa Gramarye, mostly to do with my game in the main thread.
Mostly cosmetic edits but they're explained.
More edits to come like without her facemask then eventually her veil.
Up next is to upload the coffee sprites for GS4 style Phoenix Wright.
