Resources: Canon Character Custom Sprites
jmkrebs30
Re: Resources: Canon Character Custom Sprites
Post by jmkrebs30 »
It leads to an empty folder for me, too.
ApolloGrimoire
Post by ApolloGrimoire »
Weird, it shouldn't be doing that.
I've moved everything over to dropbox. It should be working now.
Case 1 - Nursing the Turnabout: Trial Former, Trial Latter
1230james
Post by 1230james »
Work in progress stuff. Links go nowhere significant yet, so don't bother clicking.
kwando1313
Post by kwando1313 »
1230james wrote:Still a no-go.
GIF of an attempt to open the link
Same.
Avatar made by Rimuu~
ApolloGrimoire
This is why I wish they didn't do the dropbox apocalypse. :tigre:
Does this link work? https://www.dropbox.com/s/6keyfnyly41q2 ... l.zip?dl=0
1230james
Post by 1230james »
Affirmative. Was able to DL the file.
Pretty sure you can just click this Share Folder button on the right-hand side of the screen while having the root folder open.
I was able to generate this link by pressing the same button, which should open a folder with some old background assets.
You don't need to know about the purpose of rainbow GIF
ApolloGrimoire
Do I need to share the folder with Unas?
Edit: I've fixed the Defence Attorney section that needed download links.
Then when I checked imgbox...
Dear User,
We’d like to inform you that we will be shutting down services on June 30th, 2017. Please download and backup your files before this date.
Sincerely,
The Team
1230james
Post by 1230james »
ApolloGrimoire wrote:Edit: I've fixed the Defence Attorney section that needed download links.
You needn't make a link for every single DL. Sharing the root folder with a link should be sufficient.
Edit: Some other sections are missing some DL links here and there.
Dear User,
Sincerely,
The Team
And the Dropocalypse spreads
ApolloGrimoire
I've started work on adding everything to imgur. First up is a new entry with Takethat's Phoenix Wright.
ApolloGrimoire
Imgur's just not working for me on a reliable basis. Are there any other alternatives I can use?
Edit: I checked to see if it was Opera, so I doubled checked with firefox and the issue is still there. Image uploaded but the page for the uploaded image is broken.
1230james
Post by 1230james »
Don't see why imgur wouldn't work. Imgur Pro's been dead for quite some time, so there shouldn't be any image limits or anything of the sort.
Try posting a sample link here. You might just be posting the wrong link in the OP or something.
ApolloGrimoire
There's no limit's. It's just that the image uploaded just fine, but when I look a the gallery... it's not there and my browser says the page is broken.
1230james
Post by 1230james »
ApolloGrimoire wrote:There's no [limits].
I only mentioned limits because that was the only logical reason why stuff might not show up after uploading it. The idea was that they would be deleted as you upload in the masses after hitting the limit.
At least you've got stuff working now. Nice!
ApolloGrimoire
Phoenix Wright section is now up to date. I can't guarantee it'll all be updated by June 30th, but I'll try.
ApolloGrimoire
The defence attorney section is up to date.
