Ducky Sprites (I've Returneth)
Spoiler : GK2 Case 5-Shimon Aizawa :
Spoiler : AAI Case 4-Calisto Yew :
Spoiler : GK2 Hakari Mikagami :
Spoiler : AA Case 3 Jack Hammer :
Spoiler : GK2 Case 1-Mikiko Hayami :
Im part of the website Wolfduck Studios check it out if you get the chance you won't regret it. http://wolfduckstudios.com/
- DLA
- Spoken languages: English, Spanish, a bit of French
Re: Ducky Sprites
These look pretty nice, but the shading on the hair is off compared to the original profile.
The Final but not so ending chapter.
Re: Ducky Sprites
The head sprite I tweaked a little with the shading on it and yeah it does look a little off but im still practing also update,I made GK2 Character.
Spoiler : Gyakuten Kenji 2 :
Re: Ducky Sprites
Little hint: You don't have to create 4 frames for blinking. 3 are enough.
Re: Ducky Sprites
The buttons on her coat thing are off. According to her sprites, they're aligned perfectly to the center, not off to the side.
For really small detail: The lower-left lapel on her coat is curved downward in your drawing, but the original sprites show it curving upwards so it can travel farther -- over to the point of the folding flap and buttons. Basically, the curving downwards style you have is used for a single set of buttons while the curving up style is for two sets like her coat.
I like to scratch sprite. Feel free to ask if you need anything :3
Not very experienced at backgrounds, action shots, nor evidence, but I'd love to try.
Re: Ducky Sprites
pretty good froont poses for her, aside from the button placements as aer mentioned.
I have no idea if your poses are based off a base or not, so if it was scratched then good attempt
Re: Ducky Sprites
Oh, regarding the base, you can always steal Tiala's arm for that and either Trucy, Ema, Ini, Ms. DeLite, Franziska, or even Mia's base (for the turn of the hips and such. [I especially suggest Franziska's because it has so much sass in it]), but if only you wanted a more fleshed out/official base for guidlines.
- FenrirDarkWolf
Re: Ducky Sprites
I must say, those Calisto sprites are one of the best fronts I've seen of her thus far, they just need some minor tweaking as mentioned above.
AKABuddyFaithAKADiego
Spoiler : Wanted to use these as avatars, but it wouldn't let me. They're by Nibroc-Rock :
Re: Ducky Sprites
First they were too tall, now they are too short. Oh, the irony.
PS: A little hint: You don't have to make four frames of blinking sprites. Three are enough.
Re: Ducky Sprites
Thank you guys for all the advice and tweaks I needed to make.Also somehow I knew that the buttons were off I was just too lazy to worry on it but I updated it and fixed it.Also yes I did Calisto's body by scratch which I won't do again unless I draw it for real like I did with this.
Spoiler : AAI Case 3 :
Re: Ducky Sprites
Also another update I made the judge from Gyakuten Kenji 2,Hakari Mikagami because well I know we got Udgey but im sure having different judge is another cool idea too besides the Judge's brother.So I hope you like the few sprites and I plan to do more soon.
Re: Ducky Sprites
...I love them.
- ApolloGrimoire
Re: Ducky Sprites
Amazing.
Re: Ducky Sprites
Re: Ducky Sprites
Now I look at it, you should check out her breasts and neckwear.
There is definitely a difference here. I guess it should be fixed to be more accurate, right?
