Go check it out on the Court Records forums when the thread is posted!
-UltrawaveStudios
Well, you can blame Minecraft Note Block Studio for that. It only has the instruments that Minecraft has (piano/harp, bass, snare drum, bass drum, clicks), so it might seem a little bit boring. Although I DID see an "Add instrument" option, so I'll see what I can do there.DeeYo wrote:Second: The instruments. Piano, bass and drums. ...Which don't really add to the originality. Nor do they give that AA feel, but I can excuse that since you may not go for the AA feel.[/b]
Well, that's why I put it up as a draft for others to expand and improve on.1230james wrote:Whenever I hear Moderate/Moderato soundtracks, it helps me think.
This does the opposite.
Great! Can't wait to hear it then!1230james wrote:(And I think a brilliant idea hit me for Cornered music. )
^_^ Yep1230james wrote:And a side comment about the logo.
You just pulled off an infinite loop for the logo, didn't you?
The guy holds a CD.
That CD has a guy holding the same CD.
And that CD has another guy holding the same CD.
And THAT CD probably has a guy holding the same CD...
Etc.
Go right ahead.1230james wrote:My Cornered attempt kind up screwed up and it turned itself into more of an Objection theme.
Mind if I submit it as that instead? (once I'm finished, of course )
Whatever they like to use. :/V3R wrote:What do people generally use to make soundtracks for the editor?
I'm pretty sure they were asking for examples.dananddiana wrote:Whatever they like to use. :/V3R wrote:What do people generally use to make soundtracks for the editor?
