Deduction Time Limit: 1 day from the first declared deduction.
You're in an airtight room, there is a filter above the room that removes old air and replaces it with fresh oxygen. It does this every few minutes. The door is locked and there is a corpse on the ground, he looks as if he had just fallen asleep. He is wearing a party hat and is holding a slice of cake. The room is decked out as if there was going to be a party there. There are balloons slightly floating above the tables, they have their strings deposited all over the ground. There are tables all around the room with party foods on them. There is a tank for filling the balloons in the corner. On a table at the end of the room is a propaganda flyer on the dangers of vehicles along with some streamers and party poppers. There is a bunch of presents in front of that table. There are also a bunch of party hats.
Put anything directed only at the GM in spoiler tags. Please do not read other peoples spoiler tags. Have fun.
You can examine things and interact using your item. You can also activate your abilities if you wish. When you think you know the answer you can declare a deduction.
The cake is a delicious chocolate mudcake with a caramel layer in the middle. It has a thick chocolate icing and a very fluffy, rich main/base part. It's around room temperature right now. No poisons or traces of poison are evident to the naked eye but it's possible they might exist in some form...
Spoiler : Everyone (especially Sponge) :
I reply to all examinations in spoiler tags. Don't worry.
Will carefully examines the cake to see if there were any bite marks at all in the cake. He then proceeded to examine the corpse of the body more carefully.
Avatar made by Rimuu~
The cake has a small bite mark in it, as if he nibbled on it. The body seems to be peaceful as if he just fell asleep and died. There is a slight bump on his head from, more than likely, him hitting the ground but there aren't any real wounds or injuries that could have caused death. No signs of any injections, struggles, etc.
Spoiler : Joseppy :
You have tea cakes. They are small and, well, you have no way to cut them into slices. Replace it with a whole tea cake?
Spoiler : Sponge :
The body looks normal, no major wounds.
Spoiler : Sponge+Everyone :
You don't know about clues unless you have discovered them yourself or someone else tells you about them or something.
There are exactly 3 bottles in the room and one container. The first three bottles are a bottle of ketchup, mustard and barbecue sauce on the table with the food. The container I refer to is the inflation tank for the balloons.
Spoiler : Joeseppy :
There is some silverware on the table with the food. 15 forks and 15 spoons. There is one large knife for cutting cake. However! You cannot use them to cut your cake because they are clues and not your item. You can only use your item to interact with the scene and not vice-versa.
