Tips, tricks and info
Re: Tips, tricks and info
Postby enigma » Sat Apr 06, 2013 12:11 pm
Ferdie, can you explain the 2nd one to me? I've been trying it but it's just not working...
Reminder that Dancecat loves you~!
enigma
Spoken languages: miaou
Postby Ferdielance » Sat Apr 06, 2013 11:35 pm
Steps to do the same examine with different images: (Improved version for more readable code)
1. Create multiple examine images in the same directory on your imagehost. Photobucket doesn't work very well for this because it adds a lot of gibberish to the ends of filenames.
2. Create a variable called filepath with the value of your directory. So if an image is:
filepath sould be defined as:
http:\\www.fileden.com\numbers\morenumbers\
3. Create a variable called currentImage. This is where you'll store the image you want to examine. You can change it whenever you want to use a different screen in your engine. If your first image is image0.png, set it to image0
4. Create an examine frame with the background set to the EXPRESSION (check the expression box): filepath . currentImage . '.png'
5. Whenever you want to change the image, define currentImage as the picture you want to use.
6. You can't use the button to set the examinable coordinates; you need to manually enter the x1, x2, y1, y2 coordinates. One way to do this is to make another examine frame using your image, figure out what the coordinates are using that, copy them to the first frame, then delete the extra examine frame.
The practical use for this is when you're making an engine that has a lot of screens like this:
and so on.
Ferdielance
Postby Bad Player » Wed Apr 10, 2013 1:45 am
Ferdie, how long are your fades? You never actually say xP (I know there's 500/1000/1500 in the file names, but... don't want to make any assumptions ^^")
Bad Player
Spoken languages: American
Postby Ferdielance » Wed Apr 10, 2013 2:01 am
Fades last that number of milliseconds, then hold their current opacity for a second or so. This means that you can slip in, say, the 500 ms fade with any value from, oh, 50 to 60 cs, without worrying about the animation looping and giving a flicker. These animations don't loop.
Ferdielance
Postby Enthalpy » Mon Feb 05, 2018 3:44 am
For Firefox users, a remedy for backspacing out of the page when in the editor: here.
Previous
Return to Tutorials
