List of tutorials
Re: List of tutorials
Postby Singapore123 » Fri Jan 13, 2012 8:51 am
Saw the tips and tricks, but still wanted to know: Is it possible to use variables to check if and ONLY if 1 input is on. 2 inputs is easy, make those (NOT,AND,OR) gates into a XOR gate, but I want it to be like 3-5 inputs. So if one and ONLY one input is on, the output is on. If no easy way, I will have to go back to minecraft and make some logic gates...
Singapore123
Spoken languages: English, 1337, french, spanish,
Postby Bad Player » Fri Jan 13, 2012 3:38 pm
You mean, you want it to check if one and only one variable is true? It's kinda long, but you could use
(var1 & !var2 & !var3 & !var4 & !var5) | (!var1 & var2 & !var3 & !var4 & !var5) | (!var1 & !var2 & var3 & !var4 & !var5) | (!var1 & !var2 & !var3 & var4 & !var5) | (!var1 & !var2 & !var3 & !var4 & var5)
Bad Player
Spoken languages: American
Postby Singapore123 » Fri Jan 13, 2012 3:52 pm
That's the simplest one, but I can try to make it smaller, but thanks!
Singapore123
Postby Meph » Sat Jan 14, 2012 2:53 am
Post questions in their own topic in future, please, Singapore. :)
Meph
Postby henke37 » Sat Jan 14, 2012 4:37 pm
Add them up and check if the result is exactly one.
henke37
Spoken languages: Swedish,English
Postby Bad Player » Sat Jan 14, 2012 4:40 pm
henke37 wrote:Add them up and check if the result is exactly one.
I almost wrote "although henke might have a more elegant solution" at the end of my previous post :P
Bad Player
Postby Singapore123 » Sun Jan 15, 2012 6:13 am
Great Idea!
Singapore123
Previous
Return to Tutorials
