Tricks to a Cross-Examination
Postby E.D.Revolution » Wed Sep 22, 2010 8:05 am
Note: This guide will soon be outdated. If you are using v5, keep on reading. If you are using v6, go here.
Unlike my other technical guide, this guide will show you how to do a cross examination on the Editor so that it appears correctly in the Player. There are several ways one can approach the Cross-Examination, but I will be showing you the popular AA Cross-Examinations.
As with my other guide, you must know what your witness is going to say, but this time, you need to plan all of your moves before doing a Cross-Examination. The reason is because you could want the attorney to request the testimony to be amended. Also, there are contradictions to consider. I will show you how to do it.
This guide is separated into three levels: Beginner, Intermediate, Advanced. The levels are from a technical point of view, not the difficulty of the actual CE. It's up to you to determine the difficulty of the Cross Examination, and that comes from the writing. I will not be covering the writing aspect of the Cross Examination except to show what kind of limitations certain CEs have. For more information on writing contradictions for CEs, look at this writing guide and encyclopedia, courtesy of Jean Of mArc, of The Omniscient Game fame.
What the Cross Examination block looks like in the Editor.
Contradiction bar: This row shows which statement is contradictory and the correct evidence/profile to present. Make sure you know the IDs of your evidence and profiles. A newbie mistake is to mistype the ID number of the evidence or link the wrong statement to the evidence. If you do not choose a contradiction, you need to find another way to get out of the CE.
Testimony overview row: This will show what the Cross-examination will look like in the player.
WARNING!: Do NOT redirect any frame back to the testimony overview row. I repeat. DO NOT REDIRECT ANY FRAME BACK TO THE TESTIMONY OVERVIEW ROW. It will create annoying bugs.
Press conversation (If you press...): The conversation block that ensues. When the player presses the statement, the Player will run the conversation sequence as it is. After the conversation has played out, it will automatically go to the next statement. If it's the last statement, it will go to the co-council conversation.
Conversations at the bottom under display:
Co-council Conversation: The conversation that plays when the player has advanced through all the statements and has not figured out the contradiction.
Conversation if Failure: The conversation that happens when the player presents the wrong evidence. Can only be used when the player presents the evidence at the statement, not during "Press to Object" situations. If this is left blank, the player will lose 24 HP (20%) by default.
Before we start, I will say this once and only once: Do NOT redirect ANY frame back to the testimony row. If for some reason you have to go back to the testimony, either let the player take care of that for you or redirect to a blank 1 cs frame at the end of a talk, penalty, or co-council convo.
Beginner Level CEs and Techniques
This level does not require variable manipulation. After the basic Cross Examination, you will need to learn how to use other actions, such as "Ask a Question", "Ask for Evidence", "Examine area of a picture", "reveal hidden frame" and "hide frame"
Actions to learn
Ask a Question: Comes in three flavors: 2, 3, and 4 answer flavors. You need to define what the choice is. Then under the target frame, define what frame that choice goes to. Target frame number corresponds to its answer. So Target frame 1 corresponds to Anwser No. 1
Ask for evidence: Self-explanatory. You need to define the correct evidence type (evidence/profile) and the ID of said evidence. You can even restrict what kind of evidence the players can present.
Examine area of a picture: You will need to supply your own image, uploaded somewhere. Then, click the button "set coordinates" to click on the picture. First click the upper-left hand side of the area, then the lower-right hand side of the area. Confirm and complete the form.
Reveal hidden frame: Only works for statements that have the "hide" checkbox marked.
Hide hidden frame: The direct opposite of "Reveal hidden frame"
Cross-Examination: Basic
The basic cross examination is one where the contradiction is obvious. All the player has to do is present the evidence or the profile (remember, this is based on PW T&T format) and check whether the answer is correct or not. Because this is a cross-examination, each statement gets its own set of conversation blocks.
  1. First, on your last block, click the actions button and select "Enter Cross Examination." The interface will appear.
  2. Next, write out all the statements in the middle row. It must be in green.
  3. After each statement, click on add button to add the conversation after pressing the statement. Write out the conversation as you would in a normal situation. After the last block is played, the Player will go on to the next statement.
  4. When you have written all the conversations (including co-council and failure), press "contradiction" on the statement that is contradictory. The text box will ask for you to click on the contradictory evidence. Click on the top row (the ID box) and the statement will be linked to the evidence if presented.
This kind of CE is the building block to every other type of CEs. It's the easiest to make, but very limiting in terms of difficulty. You will need to employ other techniques to increase the difficulty.
Technique: Amending/Adding statements
Often times, there will situations where the player cannot find a contradictory statement. There are two ways of finding a contradiction: adding statements or amending statements. In this case, you have to make more statements than in the testimony. In this type of CE, you You follow all the rules under basic but there are a few more guidelines to follow.
The general rule for changing the testimony on the testimony line are as follows:
  • If you must add a statement, pick the statement that you wish to have the player press in order to add statement. Then create a new statement after the said statement.
  • If you must amend a statement, then pick a statement that you have to wish to press in order to amend the statement. Depending on how you structure your testimony, you can put the amended statement after the said statement.
Here's how to add statements:
On the original statement, write out your conversation. In order to add a statement, you must make a new statement afterwards. The second statement will be written as normal, but in the testimony line, it should be "hidden." In order to reveal the added statement, you must use "reveal hidden frame" action in one of the frames in your first statement conversation. The ID must match the statement in the CE block. If played correctly, when the player is done pressing the statement, the Player should go to the added statement.
Here's how to amend statements:
Follow the guidelines on adding statements, but there's an added step. Somewhere in your first statement conversation, you have to activate "hide frame." Make sure the statement in the action matches the ID of the testimony statement in the CE block. If played correctly, the Player should go to the amended statement, and the original statement should be gone.
Oh, and by the way, these type of situations almost always call for this question: "Was that last statement important?" In this case, you will have to use "Answer a Question (2 answer)" to ask the player if the new information was important before adding or amending the testimony. If it was important, then you will redirect the conversation to reflect the fact (with reveal and hide frame actions only on the "Yes, it's important" conversation path). If the player think it wasn't, then it should run the CE as if there's no need to change the testimony.
Another thing: sometimes, a press might ask for a few things to be clarified (There was a bit of information in that statement. What should I ask for?). Again, use the "Answer a Question" action to give the player choices on what should be asked. You can even put stupid answers there to throw the player off-track. In the end, if the statement might be important, you should ask the player if it was important. Usually, you would just add statements if something would need to be clarified, not amended. (Thanks to henke for pointing that out!)
In terms of writing, the player knows that the revealed statement is the contradictory statement. Always. Unless it's not, but that's rare.
Cross-Examination: Press to Object
Miles Edgeworth loves to use this type of Objection. In fact, after the the previous two techniques and CEs, this is the most common type of CE you will find in the GK/AAI series. Basically, this type of contradiction requires the player to press the statement and present the contradiction in order to get out of the CE. You shouldn't have a regular CE along with a "Press to Object" CE. But, be careful. In the AA world, when you press to object, there's always a choice to back down before you can truly attack, ie, there's always two choices: "raise an objection" and "back down." You need to program that into the CE.
Basic Press to Object
  1. In the conversation following the contradictory statement, you should activate the "Answer a question (two answer)" action so that you can put up the choices I have outline earlier.
  2. You must put up the penalty the player is facing via "flash the health bar."
  3. On the conversation following "Raise an objection" you can have a few ways to go about doing this
    • Ask for evidence
    • Answer another question
    • Point to the exact place in picture
  4. You need to provide the correct answer. For whatever method you use, you must have at least a conversation that leads out of the CE and another conversation the shows the player that (s)he has chosen the wrong answer.
Intermediate Press to Object
In this one, you can have a web of conversations going on after you have the player press the statement to try to escape the CE. Use your creativity and refer to the "Basic" version above so that you program it correctly. The one I think uses this type of "Press to Object" is Ignatius Burn's 2nd Testimony in lynx's first case in "Von Karma: Corrupt Attorney"
For this type of CE to work, the statements must be ambiguous enough to entice the players to press statements. If the contradiction is quite obvious, it becomes your basic cross-examination, therefore this type of CE does not work.
Intermediate Level CEs and Techniques
This section introduces you to variable manipulation. This will require you look at the actions "define variable", "read variable's value", and "evaluate condition"
Spoiler : Actions to learn :
Define variable's value: Self-explanatory. The good thing about this engine is that the value can accept alphanumeric values. But for simplicity's sake, stick with "1". Also, before the Player gets to the frame with this action, each variable is set to 0. This is done by default of the engine.
Read a variable's value: Self-explanatory. However, it's a bit more restrictive and tedious than...
Evaluate condition: It's a bit more complex than "read a variable's value" but a lot more flexible. Basically, this action is used to determine whether a logic statement (programming POV, not AAI POV) is true. You can easily copy/paste statements and syntaxes very easily with this.
Cross-Examination: Press-all-to-continue
Sometimes, a CE doesn't reveal a contradiction, no matter how much you press. Once all the statements have been pressed, then the next part of the trial goes on. This is what people refer as "press all to continue." Unlike present evidence ends, "press all" ends are on the intermediate level of programming. This involves variables. Now, if you haven't take programming classes (I haven't,) then don't worry. There's an easy way to make sure that the "press all" runs smoothly.
Follow the guidelines for the basic CE guide, but do not add a contradiction. There is an added step before we get into the programming part of the guide. You need to create a blank frame after the last part of the convo on each press convo. This is very important as if this isn't done, then the programming may not work correctly.
You will have to decide on the variables. The best default is
pressX
where X is the position of the statement in the testimony (press1, press2, press3, etc.). On the first frame of the press conversation, activate the "define variable" function and on the variable bar add the "press x" to it. Under the value bar, put 1. Do this for every statement.
One thing to note: All variables are initially set to 0. So you do NOT have to do this
please do not do this
define variable
variable press1
value 0
It's redundant coding, especially when the engine does this for you. So don't waste time setting each variable to 0.
On the last frame of each of the press convos (or rather, the last frame before the "continue your testimony" frame), activate the "evaluate variable" function. On the evaluate bar, put
press1=1 & press2=1 & press3=1
Okay, I bet you're asking "why are there more press values and ampersands?" Again, this has to do with the programming aspect. The ampersand is required if you are going to check all the statements have been pressed. The Player has to evaluate all the statements have been pressed, so you have to put the number of variables to check in that bar. What that sample syntax is saying is "Is press statement 1 activated? And is press statement 2 activated? And is press statement 3 activated?" In plain English, "Are all the statements activated?" If at least one of the questions is false, i.e. not all the statements have been pressed, then it will continue the CE. If the statement is true, i.e. all press convo have been pressed, then it will direct the player out of the CE.
I'll refer you to henke's thread for a tutorial about variables. It's not in the nature of the tutorial to show you how to use variables like an expert. You may also look here if you don't understand.
In terms of writing, this is best left for exploratory testimonies. Or if you're being von Karma-ish, testimonies that have no direct contradictions. This usually gives players breathing room.
Cross-Examination: Press to Obtain Evidence
Spoiler : Mastery Required: Press-all-to-continue, Adding/Amending Statements :
For this type of CE, you will have to hide evidence in certain statements. This requires a bit more planning, as it's way too easy to escape this kind of CE without the right evidence. In the official games, one never leaves this type of CE without all the evidence that is required. If testimony is an exploratory testimony, like detective testimonies, then you should employ this kind of CE.
For this type of CE, you will be employing the reveal evidence function. But you will also have to make sure the player "doesn't get the same evidence should he press the same statement again." In order to avoid this classic mistake, have a frame with the action "Evaluate condition" before the frames that give you the evidence. On that action, use the following syntax:
f:evidence_is_revealed('X',Y)
where "X" is either preuve or profil for evidence and profile, respectively (it's in French. Ask Unas for why the syntax is that way), and "Y" is the ID number of said evidence. Repeat as necessary.
After you have revealed all the evidence, you have a couple of options for escaping the cross examination. This usually means combining them with one of the other types of CEs above.
If you want to end the CE, you should consider employing tricks from "Press-all-to-continue". You will be using the "evaluate variable" function at the end of every press convo that has evidence to be revealed. In this case, instead of pressx, you will use the "evidence is revealed" syntax like as follows
f:evidence_is_revealed('X1','Y1') & f:evidence_is_revealed('X2','Y2') & f:evidence_is_revealed('X3','Y3')
and so forth.
If you want to continue the CE, you should consider "Adding/Amending Statements". You will have to use the same tricks as above (Press-all-to-continue). But this has an added coding challenge. Unlike the regular "Press-all-to-continue", this will reveal/amend statements. Again, use the "evaluate variable" function at the end of every press convo that has evidence to be revealed. Only instead of escaping the CE, redirect it to the frames that will reveal the new statement. Tag that convo with a variable, say "EvRevealed". So the syntax for that variable to say you have revealed all evidence would be "EvRevealed = 1". So that in case the player decided to press the statements again AFTER revealing the new statements, you can safely redirect the convo away from "I request a new statement" convo. I would suggest checking for that variable BEFORE you check that evidence is revealed. So a sample press convo with these elements look like this (from a technical standpoint)
Press convo
*dialogue*
Check to see if this convo's evidence is revealed.
Evaluate variable - f:evidence_is_revealed('preuve','7')
If true, goto B. If false goto A.
Branch A: Reveal evidence (In this example, reveals Evidence ID 7). Leads directly into Branch B.
Branch B: Continue convo
*more dialogue*
Check to see if amended/added statement exists.
Evaluate variable - EvRevealed = 1
If true, goto E. If false, goto C.
Branch C: Brings up another check
Check to see if all evidence is revealed.
Evaluate variable - f:evidence_is_revealed('preuve','7') & f:evidence_is_revealed('preuve','12')... etc.
If true, goto D. If false, goto E.
Branch D: Reveals a new statement. Also activates variable "EvRevealed" (Set "EvRevealed" to 1) Leads directly into Branch E. No additional coding necessary
Branch E: Ends this press convo. Continues CE
Do be careful. For this type of CE, your original statements should be factual and not contradictory at all. Otherwise, you will create gamebreaking bugs.
Advanced Level CEs and Techniques
This section requires mastery of the two previous levels. There will be even more tedious variable manipulations and a lot of actions. From a programming point of view, it can become a big headache.
Technique: Rotating statements
Spoiler : Mastery required: Press to Object and Adding/Amending Statements :
Sometimes, it's not enough to simply reveal more information. Sometimes you want the player to reveal the relevant information out of a few possibilities. The player can then ask for a statement to be revealed. But if the player can't find anything wrong with the new statement, then the player should have the option to ask for the other one. This is commonly referred to as "rotating statements". There are two basic forms: The Complex and the Simple Way.
Both forms require the techniques listed in "Press to Object" and "Adding/Amending Statements."
The Complex Way
In 1-5, Lana is testifying about her role in forging the scene. You're going to have to drag the truth out of her. But there are a few possibilities to consider in her testimony. On that particular testimony, she talks about what she forged. You can ask for the body or you can ask about the urn. In either case, the Complex Way is actually needed since you will have to press the new statement to get yet another one.
The Complex Way requires you to extract a few new statements, but you must extract it one at a time from the original statement. Follow the "Adding Statements" guide. Hide the added statements by checking "hide" in the CE text field. In the original statement where you are asked which statement to add, use the "hide a frame" and "reveal a hidden frame" actions in the choices.
Example:
What the editor says:
Original Statement... Info A (hidden)... Info B (hidden)
Under the original statement, there will be a choice using the "Answer the question (3 answers)" action. It'll look something like this:
Was any of the info he gave us very important?
Info A
Info B
None
You must create a blank frame at the end of the press convo with a 1 centisecond pause. Obviously, you know what to do for "None." But let's say you choose "Info A." In the conversation following "Info A", you must use "Hide a Frame" for the statement about "Info B" and "Reveal a frame" for the statement about "Info A." Do the same thing for "Info B." But all of the choices must converge on the blank frame.
If done correctly, it should look like this (in the player):
Before I ask for the testimony to be amended...
Original Statement... Info A... Info B (hidden)
If I choose Info A...
If I choose Info B...
Original Statement... Info A...(hidden) Info B
The Simple Way
A second variation on this type of CE is actually much simpler. Let's say you have already revealed one of the rotating statements and hidden the original statement. You can ask the player if he/she wants to switch to the other statement. Again, let's go with the Info A/Info B situation above. If you're on Info A and you want to switch to Info B, then you will have to do the following: Hide Frame Info A and Reveal Frame Info B. On Info B, do the reverse: Hide Frame Info B and Reveal Frame Info A. However, if the player opts to move to Info A from Info B, you must redirect to the last frame (hopefully empty) from the original statement. That way, the player sees the statement about Info A when you do end the convo for Info B.
The Simple Way is best used if there won't be a whole line of press statements waiting for the player.
Overall, this technique can significantly increase the difficulty of a CE, as the player is left searching for statements to object to. But at the same time, it's also very annoying to program. Use this sparingly.
Cross-Examination: Press the right statements
Spoiler : Mastery Required: Press-all-to-continue :
In case 1-2, Phoenix finds something wrong in Gumshoe's first testimony and presses the statement in order to clarify the facts. In case 1-3, Phoenix cross examines douchebag Oldbag for the last time and he had to press the right statements in order to get out of the CE. In the one of the testimonies of "The Tortured Turnabout," the player must press the right statement or risk being penalized.
All three cases highlight the concept "press the right statements." In this kind of CE, the player will have to press the right statements in order to get out of the CE. This sounds a lot like "press all to continue, right?" Well, yes and no. I'll explain below.
Situation A: Press the one correct statement to end CE.
Assuming that the player should only press one statement to get out, you can simply redirect the player to the next conversation via "skip directly to frame" action. Think Gumshoe in 1-2.
Situation B: Press the correct statements to end CE.
This requires the use of variables. For however many statements that you require the player to press, you have to tag the said statements and evaluate the condition at the end of those pressed statements' convo. It is not necessary to tag all of the statements, only the relevant ones. This is the basis to the fan-made "Super Objection" where you have to object the right evidence at the right statement. I will not be covering this, as this never appears in the original games.
Corollary to Situation B: Press the correct statements to end CE, but give the option to stop CE.
This is a corollary, an addenum to Situation B, where the player must press the correct statements before attempting to end CE. If you think there's good information in the CE that the player should read, you should combine the tagging of variables with the action "Answer a Question." The "Answer a Question" function can serve to ask the player if (s)he wants to end the CE, kinda like Oldbag's last CE in 1-3.
Situation C: Only press relevant statements
The difference between Situation B and Situation C is that Situation B gives the players freedom to ask irrelevant questions like :phoenix: press the statement (s)he deems important and Situation C penalizes the player for wasting time. You do the same thing for either Situation A or Situation B, but you will add the warning and the penalties at irrelevant statements. This is used a lot in 2-3, especially with Moe. No wonder 2-3 is known as "Turnabout Big Flop". This is an excellent way to piss players off, so use this sparingly or give a really good reason for this.
Corollary to Situation C: The Luke Atmey Testimony
Remember Luke Atmey's final testimony (3-2) in which you've only got chance to expose the contradiction? This is the corollary to Situation C, and there are a few styles, but this is what they have in common
  • They testimonies must be ridiculously long (more than 10-12 statements)
  • They contain only one contradiction.
  • There's a ridiculous penalty on the line. (at least 50%)
There are a few modifications of this type of testimony that can still be considered the Luke Atmey Testimony:
The Jin Triad Final Testimony (E.D.Revolution's "The Tortured Turnabout")
Warning: Spoiler Alert!!!
Jin Triad's final testimony: Jin Triad builds a testimony full of traps, and pressing irrelevant statements will incur the Judge's wrath. You MUST press before you present the evidence. You can't present the evidence right there. Wrong evidence will cost the player the game. There's one contradiction, and it must be presented. This has 16 statements to start.
Standard Luke Atmey Cross Examination:
  1. You must redirect the wrong press to a game over sequence. This can be done by activating the action "skip directly to frame" when the convo will take you to "Game Over."
  2. Choose the right statement and redirect it to the "success" conversation.
As long as you follow the two cardinal rules of a Luke Atmey Testimony, you will have a killer CE.
A warning, though. A Luke Atmey-style testimony is a great way to tick off your players. Employ with caution. Nobody likes to go through a lot of statements to get to the right one. And with a 100% penalty on the line, it's adds a healthy dose of frustration. Done correctly, it's a great puzzle/challenge. Done incorrectly, your players will rage-quit. This should only be done on the final testimony.
I hope I have covered most of the basic Ace Attorney Cross Examination styles. If there's any wrong information or anything you think I missed, please reply below.
Last edited by E.D.Revolution on Mon Nov 03, 2014 7:20 pm, edited 15 times in total.
E.D.Revolution
Re: Guide: Tricks to a Cross-Examination
Postby ApolloGrimoire » Wed Sep 22, 2010 8:52 am
Very impressive guide here, very detailed and easy to read. :nod:
Case 1 - Nursing the Turnabout: Trial Former, Trial Latter
ApolloGrimoire
Postby E.D.Revolution » Wed Sep 22, 2010 8:54 am
Thank you very much! :D
You know, I've only created one trial and working on a second one, and I kinda figured most of the common ones out already.
E.D.Revolution
Postby henke37 » Wed Sep 22, 2010 9:49 am
You missed the "was that important" questions.
henke37
Spoken languages: Swedish,English
Postby ApolloGrimoire » Wed Sep 22, 2010 10:43 am
Oh yeah and that was the one I keep getting messed up on in my trial too. I think it was solved in my topic a few days ago.
ApolloGrimoire
Postby E.D.Revolution » Wed Sep 22, 2010 3:57 pm
henke37 wrote:You missed the "was that important" questions.
Fixed. It's under the heading "Adding/Amending Statements"
E.D.Revolution
Postby henke37 » Wed Sep 22, 2010 4:28 pm
That was the vaguest explanation I have seen for several months.
henke37
Postby E.D.Revolution » Wed Sep 22, 2010 5:07 pm
Henke, you might want to help me word it better.
E.D.Revolution
Postby Blackrune » Wed Sep 22, 2010 6:28 pm
This sums up all the possibilities there are. Well, I remember a rare case in 1-4 where you had to scroll through the CE three times before it continues... There's also something I did somewhere in my trial: Multiple possible statements you can add, but only one at a time. So If you got the wrong one added, you have to press again to switch it with another. It's a little variation of "adding statements"...
Another variation would be that you'd have to add a statement which gives you new evidence or changes the relevance of certain evidence. However, the statement that's now contradictory isn't the added statement but another one which seemed harmless at first. For that to work, you'd need to have a variable-check right after the CE which redirects you back in if the conditions are not met. (not necessary if you got new evidence through pressing, but if the added statement changed the meaning of another statement, you'll probably need this.)
Well, those are just some ideas for variations... but most of the time the basics are sufficient. And this guide does a good job of covering those. Well done. ;)
Blackrune
Postby Phantom » Wed Sep 22, 2010 11:13 pm
Thanks for doing this, it really helped :p
Phantom
Postby Tap » Thu Sep 23, 2010 12:57 am
Blackrune wrote:There's also something I did somewhere in my trial: Multiple possible statements you can add, but only one at a time. So If you got the wrong one added, you have to press again to switch it with another. It's a little variation of "adding statements"...
Could you explain how to do this? I looked through the AAO Forums and I couldn't find a guide on how to explain doing this. :/
Thanks in advance. :D
Tap
Postby E.D.Revolution » Thu Sep 23, 2010 2:10 am
Are you talking about "revolving statements?" Like Nathan Valon's 1st Testimony in Narokh's "Matt Silver: Turnabout Deception part 3"
E.D.Revolution
Postby Blackrune » Thu Sep 23, 2010 10:30 pm
Yes, that's one way to do it. You just need to give the option to amend the statement on all involved statements. Then you just hide the statement and reveal the other one. And do the same in that one to create an endless circle. That's the easiest way to do it.
(I did it a little differently so that you have to press the statement right before the added statement to switch said statement, but that would be harder to explain.)
Blackrune
Postby E.D.Revolution » Fri Sep 24, 2010 3:56 am
Blackrune, Tap, I have this you covered for this technique.
Advanced technique: Extracting a new statement, one at a time.
This requires the techniques listed in "Press to Object" and "Adding/Amending Statements."
The way I see it is that you want to extract a few new statements, but you must extract it one at a time from the original statement. Follow the "Adding Statements" guide. Hide the added statements by checking "hide" in the CE text field. In the original statement where you are asked which statement to add, use the "hide a frame" and "reveal a hidden frame" actions in the choices.
Example:
Info A
Info B
None
I'll add an advanced techniques part to the guide if I have enough requests for one.
E.D.Revolution
Postby Phantom » Mon Sep 27, 2010 1:59 am
Hey E.D, I'm trying to do the press all to continue, but am I supposed to do the define a variable and evaluate variable for EACH pressing conversations, or just for the first one?
It's a little bit vague, a step-process would work.
Phantom
Next
Return to Tutorials
