Tricks to a Cross-Examination
Re: Guide: Tricks to a Cross-Examination
Message par E.D.Revolution » Lun Sep 27, 2010 2:20 am
Somebody already posted the guide on this. Click on the link in the "press all to continue" to see.
Basically, you have to define each variable on each press convo to tag that convo as "pressed." You will have to evaluate the condition at the end of the convos via "evaluate condition." You have to evaluate EACH variable in the CE and check that they are all pressed in order to escape the CE. If the condition has not been met, then you will have to redirect the conversation to continue the CE, within the same press convo.
E.D.Revolution
Message(s) : 5721
Message par Phantom » Lun Sep 27, 2010 2:31 am
Aha! See, the guide never stated I had to do it for EACH press convo :p
I'll try again and post back the results, forget the newest PM I sent you.
Phantom
Message par E.D.Revolution » Lun Sep 27, 2010 2:35 am
Whoops. :oops: I forgot to mention that in the beginning. Thanks.
I've updated the guide to reflect the fact.
E.D.Revolution
Message(s) : 5721
Message par Phantom » Lun Sep 27, 2010 2:56 am
Cool beans, should be easier to understand now.
Phantom
Message par Sitien maker » Sam Déc 25, 2010 10:19 am
I read that guide but i never see how to CHANGE a statament not ADDING(I think,hide frame and reveal the other frame)
PS:This is only an answer i am not trying to do this...
Yay Ace attorney.
:objection:
Some one steal my signature!<---But can't steal that line!
Sitien maker
Message(s) : 150
Langues parlées: English,Italian,and little french
Message par E.D.Revolution » Sam Déc 25, 2010 10:33 am
Umm... It's called "Amending a Statement." Check again. It's there.
E.D.Revolution
Message(s) : 5721
Message par ApolloGrimoire » Ven Fév 11, 2011 1:08 am
In 3.5 and some cases in the 4th game I think (Alita Tiala most notable), there were times after finding a contradiction you had to return to the cross examination to find stronger evidence in an amended statement, is it possible to do that in the editior?
I want to use that in Part 4 of my game.
Case 1 - Nursing the Turnabout: Trial Former, Trial Latter
ApolloGrimoire
Message(s) : 1771
Message par Bad Player » Ven Fév 11, 2011 1:19 am
Do it the same way you would normally add/amend statements, but you gotta do the coding in the contradictory dialogue instead of the press statements.
Bad Player
Message(s) : 7213
Langues parlées: American
Message par flitchard » Jeu Fév 17, 2011 9:01 am
Is there any way to do a De Killer moment? You know, the time when Phoenix had to say that a statement was not important, then attempt to add a different statement?
When ending a post, always attach a sig. That's one of my rules. :godot:
flitchard
Message(s) : 251
Message par E.D.Revolution » Jeu Fév 17, 2011 1:52 pm
That requires the complex use of "Answer a Question" and "Ask for evidence."
But this doesn't not fall under the scope of a cross-examination guide. Please ask this question in the "Questions about the Editor" Forum.
E.D.Revolution
Message(s) : 5721
Message par SwagmaWampyr » Jeu Fév 17, 2011 2:29 pm
flitchard a écrit :Is there any way to do a De Killer moment? You know, the time when Phoenix had to say that a statement was not important, then attempt to add a different statement?
All this is is just doing the "press to add" in reverse anyway, isn't it?
The one and only Rated B member.
Engaged to Gumpei <3
SwagmaWampyr
Message(s) : 7338
Langues parlées: English, Basic 1337
Re: Tricks to a Cross-Examination
Message par DLA » Dim Mars 25, 2012 11:57 pm
Sorry for necro, but I find it kind of confusing. I'm trying to make a Press All to Continue testimony, and I'm on the step that says to type press1=1 & press2=1 & press3=1 on the evaluate bar, but there is none. There's only an expression bar, a frame if success bar, and frame if failure bar, but no evaluate bar.
"Having an aura of menace is like having a pet weasel, because you rarely meet someone who has one, and when you do it makes you want to hide under the coffee table." -Lemony Snicket
Credit to the fantastic GotMLK7 for the Sonia in my av and the Top Hat Squad in my sig, and the magnificent hershel_layton for the Merle in my sig!
The Final but not so ending chapter.
DLA
Message(s) : 2066
Langues parlées: English, a little French, Saturnian
Message par Bad Player » Lun Mars 26, 2012 12:05 am
Put it in the "expression" field.
Bad Player
Message(s) : 7213
Message par DLA » Lun Mars 26, 2012 12:05 am
Thanks! :D Also, it says to put pressx and 1 in every statement's Define Variable's Value box, but what if I need to reveal evidence in one statement and can't do that at the same time? Will it still work as a Press All to Continue testimony?
DLA
Message(s) : 2066
Message par E.D.Revolution » Lun Mars 26, 2012 12:25 am
If you need to reveal evidence in that press convo and it's a "press all" CE, it wouldn't matter anyway. Since it's kinda implied you need that evidence to escape, you can do it in the same convo, just not in the same frame.
E.D.Revolution
Message(s) : 5721
PrécédentSuivant
Retour vers Tutorials
