Tutorial: How to make a map with "MS Paint"
Règles du forum
Message par Broocevelt » Jeu Nov 04, 2010 8:12 pm
Creating a Map
There are several ways to create a map. This is the best one, and will be almost as in AA.
We will be using Microsoft Paint.
Let's take an original map:
Spoiler : Original :
As you can see, there are some rules for the maps.
  • No square borders. Round borders only.
  • Windows are represented as a thiner wall.
  • Objects outlines are thiner than the walls.
  • There is a color for inside/outside the buildings.
  • The object outline is the same color as the wall, same for letters.
  • Letters have a white outline.
These are the AA-style rules. But here are some rules that make it more esthetic.
  • The inside of the objects can have a light gray.
  • The doors also can have a light gray.
Here is the color scheme I use.
Spoiler : Clolor scheme :
And for the sizes:
  • Walls: 3 pixels (4 for big walls, 2 for thin ones)
  • Windows: 1 pixel.
  • Objects: 1 pixel.
Anyway, you'll only have to care about the walls. I made the objects for you.
First, create a 256x192 blank image.
You can do that by creating a new file, and then going to "Image / Attributes".
Use the bucket and put the "outside" color.
Take it from the color scheme I showed you before, by using the "Copy Image" tool.
Make the basic rooms.
Start making the rooms you want to show with this tool:
Remember to use a 3px width. To do so, hold "-" (minus) some seconds, and press "+" twice.
Also, remember to be using the brown color from the color scheme.
Fill the rooms with the appropriated color.
Use the bucket to do so, and take the right color from the scheme.
Put the doors between the rooms that are connected.
Use these doors. Use the "copy image" tool. (Right click on the images).
Image - Image
You can rotate the doors obviously as you wish.
Create the windows.
Or more precisely "erase 2 lines of pixels from the wall".
Leave 1 line of pixels in the middle of the wall instead of 3 to represent the window like in the original map.
Put the objects.
I have some objects for you here. You can take them by using the "Copy image" tool.
Couch: Image
Round object: Image
Rectangle object: Image
And of course, you can rotate them as you wish.
Put the Killer, the Victim and eventually a Witness.
Here you have them:
Put the location names.
The font you must use is "Verdana". (It comes with Windows). Size 8, Bold.
And the color is the one from the walls.
Verdana looks like this (Without the color you should put)
Make the white border for the letters.
Now you should do this manually. Make the outline by tourself to make it look like this:
And now you should have your map done!
I used this technique and achieved this:
Spoiler : Result :
You should be able to do something even better with this tutorial.
Post what you managed to do here! :D
~Holhol is the bestest friend anybody could ask for~
♫ Check my musics! ♫
Broocevelt
Message(s) : 7319
Langues parlées: ES/FR/EN/DE
Re: Tutorial: How to make a map with "MS Paint"
Message par Blackrune » Jeu Nov 04, 2010 10:47 pm
This is a very nice tutorial.
Exactly what I needed to do a little map for the second case of my series.
You wanted to see the results, so here is mine:
Blackrune
Message(s) : 3772
Langues parlées: English, German, Japanese
Message par Broocevelt » Ven Nov 05, 2010 2:11 am
Great! I love to see people getting good results with what I show them :D
It's really well made :)
Broocevelt
Message(s) : 7319
Message par gotMLK7 » Ven Nov 05, 2010 3:08 am
I think this was a great idea! I made two versions of the Wonder Bar with it, showing two different times in my fanfic chapter, Turnabout Shock.
Spoiler : The Wonder Bar :
Wonder Bar map 1.png (7.54 Kio) Consulté 6298 fois
Wonder Bar map 2.png (6.61 Kio) Consulté 6298 fois
The (T) is Trucy, the (K) is the killer, the (V) is Suzan Prize, the victim, the (C) and (W) are my two witnesses, Charles Edwin-Ocscar and Harvey Wallbanger. The (M) is a mannequin, which is extremely important in the case.
Do they look good? (=3)
Hersh/Fiendy has credit for the amazing GiGi pics and enigma has credit for the adorable Kenshin Mega Man sprite!
gotMLK7
Message(s) : 5920
Localisation : I could tell you, but then I'd have to KILL YOU...
Langues parlées: English, learning French
Message par paradoxinparticles » Ven Nov 05, 2010 5:33 am
gotMLK7 a écrit :I think this was a great idea! I made two versions of the Wonder Bar with it, showing two different times in my fanfic chapter, Turnabout Shock.
I think those look AWESOME.
The only issue I have is that there's way too much green.
Check out this thread: http://www.aceattorney.sparklin.org/forum/viewtopic.php?f=28&t=4090 to see how the witness colours usually work :)
call me Parrie
"I will not fear. Fear is the mind-killer. I will face my fear and will let it pass through me."
-Frank Herbert
I make boxart now
paradoxinparticles
Message(s) : 1593
Genre: Féminin
Langues parlées: English, French
Message par gotMLK7 » Ven Nov 05, 2010 5:44 am
Better? :sawhit:
Wonder Bar map 1.png (7.55 Kio) Consulté 6287 fois
Wonder Bar map 2.png (7.36 Kio) Consulté 6287 fois
gotMLK7
Message(s) : 5920
Message par paradoxinparticles » Ven Nov 05, 2010 6:27 am
gotMLK7 a écrit :Better? :sawhit:
Much! That's looks awesome :):):):)
call me Parrie
-Frank Herbert
I make boxart now
paradoxinparticles
Message(s) : 1593
Genre: Féminin
Message par Broocevelt » Ven Nov 05, 2010 2:59 pm
I'm amazed with what people can do with this :D
Broocevelt
Message(s) : 7319
Message par Quadratic » Sam Nov 06, 2010 4:55 am
Should've did it this way instead of the way I did it in my trial... won't bother to change it though. I'll keep this in mind for next case, though~ :D
Finished Trials:
Turnabout Transfer - Day One: http://aceattorney.sparklin.org/jeu.php?id_proces=19354
FABULOUS!
Quadratic
Message(s) : 153
Message par FenrirDarkWolf » Dim Nov 07, 2010 2:56 am
It's not perfect but...
FenrirDarkWolf
Message(s) : 7521
Message par Broocevelt » Dim Nov 07, 2010 8:46 pm
Hey, it's preety neat, don't worry about it ;)
You should just recolor the characters letters to white.
Oh, and BTW, you made the letters outline perfectly! :D
Broocevelt
Message(s) : 7319
Message par FenrirDarkWolf » Dim Nov 07, 2010 8:53 pm
Any better?
FenrirDarkWolf
Message(s) : 7521
Message par Broocevelt » Dim Nov 07, 2010 8:53 pm
Yes, that's what I meant. Perfect ^^
Broocevelt
Message(s) : 7319
Message par FenrirDarkWolf » Dim Nov 07, 2010 9:02 pm
Thanks! (=3)
FenrirDarkWolf
Message(s) : 7521
Message par adart » Dim Nov 07, 2010 9:26 pm
This is so helpful!
Here were my outcomes, for the first case in my series;
(I couldn't be bothered to sit and draw the outlines for the text.)
Pièces jointes
Map B.png (4.48 Kio) Consulté 6168 fois
Map A.png (4.12 Kio) Consulté 6168 fois
Mein erster Fall Odell Thurk: Ace Attorney, 0% fertig in der deutschen Sprache. Übersetzung wird getan, wenn englische Version fertig ist. Mein Deutsch braucht ein bisschen Arbeit, aber ich denke, ich kann im deutschen Forum mit Leichtigkeit Post jetzt!
adart
Message(s) : 42
Langues parlées: English, Français, Deutsch
Suivant
Retour vers Art Guides
