Tutorial: Making Crossover Sprites
Règles du forum
Message par gotMLK7 » Ven Nov 12, 2010 8:51 am
Hey there! I thought I'd share my method on how to make sprites from other series. To be honest, I just wanted to make a tutorial for the tutorial thread, and this was all I could think of. :| If this is of any use to you, I would love to see the results!
BTW, this is my method, and I use bases for spriting, so if you make sprites from scratch, you can throw about half of this to the wind and just take my advice on coloring and shading. This advice is also good for normal spriting in general.
Spoiler : Part 1: References :
Spoiler : Part 2: The Head :
Spoiler : Part 3: The Body and Final Result :
I hope this is of use to you!
Hersh/Fiendy has credit for the amazing GiGi pics and enigma has credit for the adorable Kenshin Mega Man sprite!
gotMLK7
Message(s) : 5891
Localisation : I could tell you, but then I'd have to KILL YOU...
Langues parlées: English, learning French
Re: Tutorial: Making Crossover Sprites
Message par Dypo deLina » Ven Nov 12, 2010 8:57 am
Hey, not bad at all. :D
But atm, I'm leaning a bit more towards scratch spriting, so... :/
チラセ・マギタ
~Loving father to ZetaAzuel~
Image Image
Dypo deLina
Message(s) : 5528
Langues parlées: English, Dutch, German, French, Spanish, Al Bhed
Message par Tap » Ven Nov 12, 2010 9:13 am
Impressive tutorial. ^^
I'll add it to the list.
On a completely random note, maybe I should make a tutorial one of these days... :P
Tap
Message(s) : 4799
Message par gotMLK7 » Sam Nov 13, 2010 1:37 am
Dypo a écrit :Hey, not bad at all. :D
Then you can ignore the advice about references and just use my tips on spriting in general. That's the beauty of the tutorial!
gotMLK7
Message(s) : 5891
Message par Aer » Ven Août 24, 2012 5:32 am
Nice tutorial, I like the sprite :nod:
I think the twist at the top of his hair is supposed to be wavier to resemble a spirit flame.
I think I'm going to try to sprite this person, too. See how it comes out owo
I like to scratch sprite. Feel free to ask if you need anything :3
Not very experienced at backgrounds, action shots, nor evidence, but I'd love to try.
Aer
Message(s) : 232
Genre: Féminin
Message par Phantom » Ven Août 24, 2012 8:25 pm
That is one weird looking tie.
That's also a lovely looking dunce hat ;p
Edit: finally got a proper pc to type on, check this out, I'm critiquing your final result:
1) The tie needs a complete rework when it reaches the bottom...It looks as though it's expanding, that's not how ties work yo :P
Shading is acceptable though.
2) Should I even need to bring out the problem regarding the shirt collars?
3) The bottom two-piece "collars" on the red jacket is too short, it needs to be longer like sissel's actual jacket.
4) There needs to be actual shoulder-pads to his jacket, since his suit-jacket is pretty special. Your version is just some regular run-of-the-mill loose-fit suit.
5) His skin color is pretty lighter than how you have it right now.
6) The nose is NOT accurate at all.
7) Same with the glasses, not accurate at all. His glasses are more sharply triangular shaped where your version is more circular-rounded.
8) The hair is just an eyesore to look at. Shading-wise it's bad, color-wise it's just as bad.
9) There is no proper perspective on the hair itself...as I said earlier, it looks like a dunce-hat since it's extremely flat to my eyes.
10) What is up with the front part of the hair (at his forehead)? The hairline should be completely flat, don't need "fluffy" hair in the front. Needs rework.
11) His arms (going below the elbow) should be a little bit skinnier.
12) The little "twinge" at the top of his hair...Yeah that's not a good one.
The cross-over sprite...it's pretty disappointing to see the final result Got. The tutorial itself is alright but the result is not something anyone wants to have when *seriously making an attempt to do a cross-over sprite.
If your final result was a first rough draft version, then I'd say it's a good job, but no way that should look like a final result.
Phantom
Message par Ise no Kami » Lun Juil 18, 2016 5:18 am
I'm just using vectors for this (my set of cases are an MLP crossover), but I will have to make some OCs from scratch...
Ise no Kami
Message(s) : 23
Retour vers Art Guides
