Tutorial: How to make a witness sprite w/GIMP and Paint.NET
Règles du forum
Message par FenrirDarkWolf » Sam Nov 13, 2010 7:59 am
I made this for people who wish to go to court, but have no witness sprite for it.
MAKING IT FROM SCRATCH!
First off create a 128 by 128 canvas.
Add transparency, if not already done, and cut the background.
Begin with the original sprite from the game.
Create outline and add base color while looking at a reference sprite.
Image(It's white so you guys could see the outline, you can cut it out later Image
Add shading, lines and details.
The result!
MAKING IT BY USING A BASE!
First, take your base you'll use, I used Chris.
Open the game's sprite.
Color the shades accordingly from colors from the game sprite to the witness sprite. Tip:Turn tolerance to zero.
If the sprite does not have a neck, add a neck from another sprite, or free-draw it, I used Hobo Nick's neck.
Remove extra pixels and and recolor hair if hair is on clothes.(Pixels in red will be removed.)
If not done so finish recoloring clothes.
Change the head and fill with the base color.
Remove any extra pixels if necessary, and shade accordingly, remember details, especially for hats and hair, do not need to be perfect, just close enough so it cannot be told apart for the original.
The finished result.
FenrirDarkWolf
Message(s) : 7521
Langues parlées: English
Re: Tutorial: How to make a witness sprite w/GIMP
Message par gotMLK7 » Sam Nov 13, 2010 8:22 am
It looks off proportioned. Compare it to other witness sprites for size references.
Hersh/Fiendy has credit for the amazing GiGi pics and enigma has credit for the adorable Kenshin Mega Man sprite!
gotMLK7
Message(s) : 5920
Localisation : I could tell you, but then I'd have to KILL YOU...
Langues parlées: English, learning French
Message par Tap » Sam Nov 13, 2010 8:58 am
You're on the right track, Diego, but you just need to clean it up. Like gotMLK7 said, the sprite is disproportionate compared to other CRO sprites. Also, instead of just explaining "create an outline and colour it in", refer to example CRO sprites and have many screenshots showing the process. Also, make sure you cut the screenshots so they don't take forever to load.
Refer to Singidava, Hikari Yamija and gotMLK7's tutorials for good examples in presentation. =D
Tap
Message(s) : 4799
Message par LunchPolice » Sam Nov 13, 2010 9:30 am
Tap a écrit :Refer to Singidava, Hikari Yamija and gotMLK7's tutorials for good examples in presentation. =D
*feels inadequate*
But in all seriousness, lol, Tap is right. It needs more steps in explanation. Also, it would help if
when you used print screen, you cut out the relevant parts and just showed us that, keeping
the pictures small and not full of your entire screen.
I make stuff sometimes
Image trophy x 5
MIND-FREAK
LunchPolice
Message(s) : 2348
Langues parlées: English, Namekian, Pezazulian
Re: Tutorial: How to make a witness sprite w/GIMP and Paint.
Message par Tap » Dim Nov 14, 2010 8:29 am
Great job in fixing it up but it still needs to be cleaned up a bit. This is all you need to fix and then I'll add it into the list.
The result, it looks off, I know.
If yours looks off, then no doubt any readers might have the assumption their's will turn out the same way. You need to create a good example to demonstrate your tutorial works. Otherwise... ;)
Tap
Message(s) : 4799
Message par Phantom » Lun Nov 15, 2010 3:22 am
I think it looks REALLY good now!
Phantom
Retour vers Art Guides
