Art Questions and Answers:
Forum rules
Postby Singidava » Thu Nov 24, 2011 8:21 pm
This thread is for all questions related to art, spriting and digital painting. The questions and answers will be added to this post to make information easy to find for everyone.
GENERAL:
Q: What's the best program for spriting?
A: People here use very different programs, so I'm afraid there is no single answer. However, the most common ones are Paint.Net, GIMP and MS Paint.
MS Paint is the default Paint that comes with Windows. It lacks layers but is very easy to use. Paint.Net and GIMP are free image editing softwares. GIMP is the most versatile and well suited to scratch spriting, but it's also the most complicated one. If you plan frankenspriting I'd recommend using Paint.Net.
Q: What do the terms frankenspriting and scratch spriting mean?
A: Frankespriting means making a new sprite by combining parts of already existing sprites into a new one. Scratch spriting is drawing the whole sprite completely by yourself.
Q: How big should my sprite/background be?
A: Small enough to fit into DS screen size which is 256 x 192. You might find it easier to first draw the picture in bigger scale and then resize it to fit the screen.
Q: How do I make profile pictures?
A: Get a profile image of any character, cover the entire block with the same gray colour, and place your headshot of your sprite on it.
Q: Which font should I use for my boxart?
A: Either Georgia Bold or Times New Roman Bold.
SPRITE TRANSPARENCY:
Q: How do I make the background transparent?
A: First copy your picture to a new transparent mode layer (this means if this layer is empty it is transparent. Usually programs create transparent layers by default). Then delete the original layer. Now you can erase the unwanted background from the transparent layer and save. When saving it's important to save in a format that can handle transparency. The most common ones are .png and .gif. If you save in .png you also have to remember to save it in correct mode.
In Adobe Photoshop(s) you must choose "interlaced" when saving the picture.
In GIMP uncheck the "save background colour" option when you're saving the picture.
In Paint.Net Simply save your picture as .png. Save configuration should be set to 32 -bit.
In Paint Tool Sai copy your sprite to a transparent layer and delete its background. Set the layer under the picture invisible. Then save your picture by clicking File > Export As > .png (PNG). The program asks you pixel format and you should choose the lower option "32 bpp ARGB (Each pixel have opacity)". Now you have a transparent .png file.
MS Paint can't save transparent pictures.
COLOURS:
Q: When I try to edit a picture the colours go wrong! Help me!
A: The cause of the problem is either .gif format that can only handle a predetermined palette or indexed colours mode if the picture is in .png. There are several ways to avoid this problem. Here's a few:
  • Change the mode from indexed to RGB. In the most programs the route for this is Image > Mode > RGB.
  • Save the picture first in some other format and then reopen it.
  • Open it in a program that can't read indexed colours such as MS Paint and save it there. When you reopen it the indexed colours have disappeared.
  • etc.
Q: There is noise in my sprite! What do I do?
A: Unfortunately, you've saved your sprite in .jpg and that noise is extremely difficult to get rid of. In some programs such as Photoshop there are filters to reduce the noise, however, all they do is reduce. Usually the best solution is to remake the sprite all over again.
Never save your sprites in .jpg!
ANIMATION:
Q: How do I animate a sprite?
A: Sprite animations are usually GIFs with multiple frames. There are a few guides here and here that cover animating talking and blinking on sprites.
Q: What's the most efficient/effective way to make sure all your sprites are positioned exactly the same in GIMP?
A: There is something called a "guide." To access this, use the move tool (hotkey "M"). Click and hold from the rulers. Then drag down to the desired position. When you copy-paste sprites and move them around, it should snap to the guides.
Q: How many frames do I need for animating my sprite and what's their correct order?
A: For a blinking animation you need three frames: eyes open, eyes half-open and eyes closed. For a talking animation you need open, half and closed frames for the mouth. Remember that when people talk they usually don't stop blinking. Therefore you also need open, half and closed animation for the eyes. Different spriters usually use diferent orders for frames with so there is no common consensus about the "correct order". Just use the order that you think looks the best.
Singidava
Spoken languages: Suomi, English & 日本語
Re: Art Questions thread
Postby Dypo deLina » Thu Nov 24, 2011 8:31 pm
I don't mind answering questions about that (because they totally make me look smart *shot*), but I do agree that it'd be a good idea to compile a list. :)
チラセ・マギタ
~Loving father to ZetaAzuel~
Image Image
Dypo deLina
Spoken languages: English, Dutch, German, French, Spanish, Al Bhed
Re: Art Questions and Answers:
Postby Singidava » Thu Dec 29, 2011 5:01 pm
Since there seems to be no opposition and the mods have apparently approved this (the title was changed without me touching it) I've proceeded adding the first questions and answers. When we get more of them I may have to make a proper index but currently there are so few I didn't bother making one.
Singidava
Postby DLA » Tue Mar 13, 2012 2:08 am
To make a transparent background in GIMP, do you use the same method?
"Having an aura of menace is like having a pet weasel, because you rarely meet someone who has one, and when you do it makes you want to hide under the coffee table." -Lemony Snicket
Credit to the fantastic GotMLK7 for the Top Hat Squad in my sig, and the magnificent hershel_layton for the Merle in my sig!
The Final but not so ending chapter.
DLA
Spoken languages: English, a little French, Saturnian
Postby Wolf Speaker » Wed Mar 14, 2012 12:32 am
I was wondering...does anybody else here use Paint Tool Sai? I always use it for drawing and I was wondering if it'd be fine for spriting too.
Shuìlián - Lv.9
Adaptability
- Helping Hand
- Growl
- Tackle
- Tail Whip
- Sand-Attack
- Baby-Doll Eyes
Mr. Darcy - Lv.8
Pick Up
- Odor Sleuth
- Tackle
- Growl
- Defense Curl
- Flail
Allistair - Lv.9
- Tackle
- Dragon Rage
- Focus Energy
- Bite
Wolf Speaker
Spoken languages: English, French, Chinese
Postby Dypo deLina » Thu Mar 15, 2012 9:54 am
Mii-sama uses Sai for paintings, but I don't think she uses it for sprites...
チラセ・マギタ
Image Image
Dypo deLina
Postby Singidava » Fri Mar 16, 2012 11:17 pm
Detective Luke Atmey wrote:To make a transparent background in GIMP, do you use the same method?
That method works with GIMP yes. If your background has only one colour you can also try removing it using "select by colour" and delete. This works as long as you don't have your picture on the default white background layer.
Wolf Speaker wrote:I was wondering...does anybody else here use Paint Tool Sai? I always use it for drawing and I was wondering if it'd be fine for spriting too.
If you can do it with MS Paint you can do with Sai also. Just make sure that it can save transparency or otherwise you have to remove the backgrounds with a different program. I don't personally use Sai but some of my IRL friends do. They're digital painters not spriters though.
Singidava
Postby Wolf Speaker » Sun Mar 18, 2012 12:34 am
How do I make my background transparent on Sai or Paint? I've tried a couple of things, but it didn't work.
Shuìlián - Lv.9
Adaptability
- Helping Hand
- Growl
- Tackle
- Tail Whip
- Sand-Attack
- Baby-Doll Eyes
Mr. Darcy - Lv.8
Pick Up
- Odor Sleuth
- Tackle
- Growl
- Defense Curl
- Flail
Allistair - Lv.9
- Tackle
- Dragon Rage
- Focus Energy
- Bite
Wolf Speaker
Postby Zombie » Sun Mar 18, 2012 12:48 am
Wolf Speaker wrote:How do I make my background transparent on Sai or Paint? I've tried a couple of things, but it didn't work.
You can't make transparent backgrounds on paint. Sai... I'm not sure since I don't have it.
Zombie
Spoken languages: English, My written french is horrible.
Postby Koda » Sun Mar 18, 2012 12:52 am
Use the magic wand to select the background colour and then ctrl+x.
Koda
Spoken languages: mainly english tbh
Postby Wolf Speaker » Sun Mar 18, 2012 2:32 am
But when I do that, there's a small part of the characters' outlines that gets erased with it.
EDIT: Nevermind. I got it. Except there's still a tiny bit of the outlines that are erased.
Shuìlián - Lv.9
Adaptability
- Helping Hand
- Growl
- Tackle
- Tail Whip
- Sand-Attack
- Baby-Doll Eyes
Mr. Darcy - Lv.8
Pick Up
- Odor Sleuth
- Tackle
- Growl
- Defense Curl
- Flail
Allistair - Lv.9
- Tackle
- Dragon Rage
- Focus Energy
- Bite
Wolf Speaker
Postby Koda » Sun Mar 18, 2012 6:28 am
You're going to have to play around with the tolerance of the magic wand and try to find the magic number that will select only the outlines. ;)
Koda
Postby Wolf Speaker » Sun Mar 18, 2012 4:16 pm
I managed it! :D Except it doesn't make the background transparent. I tried re-uploading it and there's no difference. :C
Shuìlián - Lv.9
Adaptability
- Helping Hand
- Growl
- Tackle
- Tail Whip
- Sand-Attack
- Baby-Doll Eyes
Mr. Darcy - Lv.8
Pick Up
- Odor Sleuth
- Tackle
- Growl
- Defense Curl
- Flail
Allistair - Lv.9
- Tackle
- Dragon Rage
- Focus Energy
- Bite
Wolf Speaker
Postby Koda » Sun Mar 18, 2012 6:20 pm
Err it always works for me. D: Can you PM me the file?
Koda
Postby Dypo deLina » Mon Mar 19, 2012 8:49 am
Did you set up an alpha channel? Otherwise it'll just turn white. (Of course, I'm not sure if there even are alpha channels in Sai... but it's worth a shot.)
チラセ・マギタ
Image Image
Dypo deLina
Next
Return to Art Guides
