I've just made a small technical update to the V6 player - more precisely to the module that renders the screen.
The objective of the change is to reduce flickering. It should avoid problems like a popup appearing after the place, two characters not appearing at the same time, etc.
Technically speaking, it buffers updates to the screen (place, popups and character) to trigger them all at the same time, whereas the previous system updated each part of the screen independantly.
Let me know if you notice any effect, positive or negative.
Player technical update - your feedback is needed !
- GanonZD
- Spoken languages: English, Danish, German, a tiny bit French
Re: Player technical update - your feedback is needed !
It had a postive effect.
Ganon er kommt zum Dorf.
