[Bug?][E] Wait Timer is Inconsistent
Message par Spyromed » Dim Oct 12, 2014 8:59 pm
I've had this problem quite a lot on V6.
Sometimes, when a wait timer is set on multiple frames, even though the number of ms. are the same, the actual wait time is vastly different. A three frame example - with, let's say, 6000 as the wait timer for both transitions - doesn't always lead to the same time being delayed between the frames. Sometimes, though, it does work as it should.
I haven't seen anybody else notice this, so it might not be an issue with the editor at all.
Spyromed
Message(s) : 498
Langues parlées: English
Re: [Bug?][E] Wait Timer is Inconsistent
Message par Enthalpy » Dim Oct 12, 2014 10:19 pm
Do you have a demo of this available? I've noticed that the wait timer isn't perfect, but I haven't come across any instances where the delay is big enough to cause a statistically significant difference.
Message(s) : 4488
Message par Enthalpy » Mer Août 19, 2015 10:23 pm
I'm going to close this as not reproducible unless a demonstration comes reasonably soon.
Message(s) : 4488
Retour vers AAOv6 Beta
