I'm playing in Windows 8 inside Chrome version 39 on the V6 player. Whenever I have AJ!Payne do the hair flip action, I'll switch to a new sprite since the hair flip doesn't have a talk animation. Problem is, once switched over to the new sprite, it tends to glitch back to the hair flip sprite temporarily
EXAMPLE: (go to frame 140, it'll be the next frame)
http://aceattorney.sparklin.org/V6_Test ... 0726&debug
HOW TO REPRODUCE:
Use the default sprite, BoulayVieux 2, set the startup animation to "play while typing." Set the frame timer to 1100.
On the next frame, use any BoulayVieux sprite other than 2 (I've noticed it on 1 and 3). Do not set a frame timer.
[P] Payne sprites glitching back and forth
