[E] Locked Into Advanced Mode
Message par Enthalpy » Ven Mai 22, 2015 6:49 am
NOT A BUG
If you select "Advanced mode" for an action and then select advanced mode for an individual option, you cannot leave advanced mode by simply clicking on the master "advanced mode" button. Attempting to do so displays as if advanced mode is off, but after confirming and reopening the action, the old advanced mode options are checked. Instead, closing advanced mode requires unchecking all the "lesser" buttons and then unchecking the master button.
Raison : Updating the OP to make it clear at a glance that this isn't a bug.
Message(s) : 4487
Re: [E] Locked Into Advanced Mode
Message par Unas » Sam Mai 23, 2015 11:38 pm
That's normal behaviour.
If a parameter is set using a runtime expression, then the editor automatically displays advanced mode, because the normal mode would not be able to open it anyway.
Message(s) : 8787
Message par Enthalpy » Sam Mai 23, 2015 11:41 pm
I could have sworn that was a change in behavior... Oh well, it makes sense.
Message(s) : 4487
Retour vers AAOv6 Beta
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 2 invité(s)
