This bug happens in Chrome. I'll test it in IE9 and Firefox later. EDIT: Forget testing in IE9. The storyboard doesn't load and it gets stuck. The other tabs work, though.
To reproduce this bug, open a large trial (more than 200 frames), open the storyboard tab and scroll to the bottom.
When I first start using the Editor, memory usage for the tab was about 44 000 k and performance was good. However, if I left Chrome idle for a while, the memory eventually went to 100 000 k and performance was very bad. While I was watching Chrome's task manager, I noticed the memory increase by 1000 k after about 5 minutes.
Also, it seems to use the CPU about every 2 seconds, even when left idle.
EDIT: I'm not positive, but I don't think this happens in Firefox.
EDIT 2: Actually, I think it does happen in Firefox as well. I think this leak happens after creating a new frame.
[Bug][E][✓] Memory leak!
- Meph
