[P] The little "arrow"
Re: The little "arrow"
Message par Exedeb » Jeu Avr 04, 2013 12:42 am
Wait a second.
The arrow is small, look this.
As you can see, the arrow isn't intrusive...
Ok, maybe a bit, but not so much.
The space that the arrow should occupy is enough for the text.
Of course I edited the picture to do an example
And then I discovered something that It could be interesting. In courtroom, during the cross-examination, there's not arrow in bottom right corner (wow...).
I think we can edit the arrow in the circumstances. Small or less, transparent or less.
Sorry if my English is not correct or wrong. Thank you.
Exedeb
Message(s) : 108
Langues parlées: Italian, English (meh)
Message par Bad Player » Jeu Avr 04, 2013 1:00 am
No matter how big/small the arrow is, it'll be intrusive in textboxes that are filled up 100%.
Bad Player
Message(s) : 7213
Langues parlées: American
Message par Exedeb » Jeu Avr 04, 2013 1:20 am
O-ok.
Sorry....
My apologies.
Exedeb
Message(s) : 108
Message par Meph » Jeu Avr 04, 2013 6:40 pm
DWaM a écrit :But... the proceed button tells the player that it's safe to click it... :/
What the button does now is:
  • show no arrow when it can't be clicked.
  • show one arrow when the text has finished typing out and you can click it to go to the next frame.
  • show two arrows (like a fast-forward icon) when the text is being typed out and you can click it to force it to finish typing.
I think the two arrows can be distracting. It would be better to always show one arrow and only show two arrows when the button is held down to skip multiple frames (which is the current behaviour in the real AA games). Showing a little arrow in the bottom right corner of the dialogue box would be less distracting and wouldn't defer the user's vision away from it.
DWaM a écrit :Putting it anywhere outside of it, or giving it a special place of its own on the screen has the potential of distracting and even making the image on the screen look... well, bad, in my opinion, at least. Putting it anywhere below the upper screen still damages you, because... Well, the big button's already there... X)
One idea I had was putting it in the margin between the top and bottom screen, but that probably won't work. Another idea that might be better is putting it above the top right corner of the dialogue box; like where the blue name box is.
Exedeb a écrit :I think we can edit the arrow in the circumstances. Small or less, transparent or less.
That's a good idea. If the arrow was 50% transparent, you'd still be able to see the text.
Bad Player a écrit :No matter how big/small the arrow is, it'll be intrusive in textboxes that are filled up 100%.
You shouldn't be writing dialogues that take up 100% of the textbox, anyway. There's a big risk that the text will spill over into the fourth line, if the user is using an operating system or Web browser that renders the font a bit wider than on your computer.
Meph
Message(s) : 13439
Langues parlées: English
Message par GanonZD » Jeu Avr 04, 2013 7:08 pm
Meph a écrit :You shouldn't be writing dialogues that take up 100% of the textbox, anyway. There's a big risk that the text will spill over into the fourth line, if the user is using an operating system or Web browser that renders the font a bit wider than on your computer.
I think there are lots of common ad hoc solutions on AAO that "should not" be used; this probably won't stop most authors from using them. And the four or so browsers that make up 99 % of the market render things like line width almost identically by now, as far as I know; the differences are getting so small they will hardly affect the width of the 7 words that make up a line in an AAO text box. And so far, AAO is not well suited for browsers on mobile devices anyway, so that's really not something to worry about either.
Furthermore, sometimes it's just not really possible to shorten the text without compromising on something. Tell Picasso never to paint pictures greater than some upper size limit... ;-)
Ganon er kommt zum Dorf.
GanonZD
Message(s) : 523
Message par Kroki » Jeu Avr 04, 2013 10:12 pm
In the original games there is some space in the lower part of the box, but it has been removed in AAO.
Meph's system for the arrow button would be as amazing an improvement as the blinking sprites were a few years ago. 8)
ImageImage Image Image Image
Kroki
Admin
Message(s) : 7427
Langues parlées: Français, English, Español, 日本語
Message par DWaM » Jeu Avr 04, 2013 10:28 pm
Yeah, but the reason the arrow is in the bottom right corner in the first place (hell, in most visual novels), is that it goes by the logic that the reader has read the text in the textbox, came to the end of it, saw the arrow.
Putting it somewhere where the nametags are... esthetically, I can't imagine it would look good, I'm afraid. It would be distracting instead of subtle. And even if the arrow was transparent, the completely-filled-textboxes would still be a bit of a problem - it would still perhaps be a bit difficult to read it.
DWaM
Message(s) : 1726
Langues parlées: English, Croatian/Serbian, some German
Message par Bad Player » Jeu Avr 04, 2013 10:33 pm
Tell that to all the major fancase makers xP
Sometimes you have complex sentences, and even cutting it down as much as you can you only get it to just barely fit in the text box.
Bad Player
Message(s) : 7213
Message par Phantom » Jeu Avr 04, 2013 11:20 pm
3rd time's the charm.
Putin a écrit :
Putin a écrit :Worst case scenario you resize it lower than it is in-game and you make it slightly transparent.
Edit: To add onto my self-quote, within the text-box.
Edit 2: To add onto my self-quote again, make it transparent enough to where you can still see the text (even change the arrow color to a grey color so you can see the white text easily behind it).
Meph, you're making the entire idea more complicated than it needs to be. Everyone here is right when it comes to these random arrow placements comments you're suggesting about.
The only logical place is the text-box, but of course, the problem is text blocking/spacing. That's why you overlay the whole thing (that is, the arrow).
It's either this, or have NO arrow at all.
Phantom
Message par kwando1313 » Jeu Avr 04, 2013 11:23 pm
I'd prefer no arrow. >_> Or, at least increase the text box size so the arrow doesn't cover up the text.
kwando1313
Message(s) : 7683
Message par Bad Player » Jeu Avr 04, 2013 11:29 pm
Yeah, I think it's easiest and best to just keep it the way it is now, with no arrow.
Bad Player
Message(s) : 7213
Message par Unas » Ven Avr 05, 2013 9:58 am
Meph a écrit :I think the two arrows can be distracting. It would be better to always show one arrow and only show two arrows when the button is held down to skip multiple frames (which is the current behaviour in the real AA games).
Except that, while it would work on a touch screen device, holding a mouse button down is a very unnatural thing to do on a computer in this case; it is usually associated with dragging and dropping information, not with keeping UI buttons pressed. And remember that computers are still the main target for AAO.
So, for the moment at least, I intend to keep the current behaviour.
Next, as DWaM said this behaviour already makes the typing status visible, since the appearance of the button changes along with its action.
Given the problems highlighted by people here with adding the small arrow to the textbox, and given that its functionality is already met in a different way, making it basically useless, I've decided not to add this feature.
Message(s) : 8787
Message par Meph » Dim Avr 07, 2013 2:40 am
Bad Player a écrit :Sometimes you have complex sentences, and even cutting it down as much as you can you only get it to just barely fit in the text box.
I've been in that situation, as well, you know. :P But I usually split them into two frames. That solution works fine. :)
Well I just suggested that too, and BP was like "Oh no, players still won't be able to read the text underneath". But yes, as I said earlier, one solution is to have an arrow with about 50% opacity. And I'm becoming more and more convinced that that is the best solution.
I've lowered the dialogue box's height in AAO6 so that it's the same size as the one in AAI. I'd rather keep it at its shorter height so that the new AAI-style features are more visible. :)
But the current behaviour doesn't allow you to skip multiple frames at once (without clicking multiple times).
Not even with transparency? *puppy-dog eyes*
Meph
Message(s) : 13439
Message par Bad Player » Dim Avr 07, 2013 2:53 am
But that's an issue about how the advancement button works. There's no reason or necessity to add in the textbox arrow if you change the way the advance button works.
Bad Player
Message(s) : 7213
Message par Meph » Dim Avr 07, 2013 2:56 am
Bad Player a écrit :But that's an issue about how the advancement button works. There's no reason or necessity to add in the textbox arrow if you change the way the advance button works.
There is, because, if this change were to happen, the proceed button would not change its icon unless you hold it down.
Meph
Message(s) : 13439
PrécédentSuivant
Retour vers AAOv6 Beta
