[Bug][P][✗] Sprite smooth scrolls when not meant to.
Message par MatthewJames5 » Sam Mai 11, 2013 2:31 pm
I have a bit of a problem.
Whenever I go to the co-council view, the background scrolls in, even when i select not to.
Also, the same happens with the prosecution's speed-lines. Can anyone offer some advice? :atmey:
MatthewJames5
Message(s) : 30
Langues parlées: English
Re: [Bug][P] Sprite smooth scrolls when not meant to.
Message par energizerspark » Sam Mai 11, 2013 2:33 pm
What browser are you using?
Currently watching:
Currently playing:
Currently reading:
The Lord of the Rings (The Return of the King) - J.R.R. Tolkien
the avatar is from Urusei Yatsura in case you were wondering
energizerspark
Message(s) : 4119
Message par MatthewJames5 » Sam Mai 11, 2013 2:37 pm
Firefox. Why?
MatthewJames5
Message(s) : 30
Message par energizerspark » Sam Mai 11, 2013 3:06 pm
If you're reporting a bug, you need to follow this template:
Bug: Describe the bug.
Browser: Your browser.
Reproducing this: How others can reproduce this bug.
Fix: Suggestion to fix it.
Currently watching:
Currently playing:
Currently reading:
energizerspark
Message(s) : 4119
Message par GanonZD » Sam Mai 11, 2013 3:40 pm
And preferably a link to a trial that has the bug.
Ganon er kommt zum Dorf.
GanonZD
Message(s) : 523
Message par Unas » Sam Mai 11, 2013 3:47 pm
Yep, if you can provide me with a link to the trial that has the problem and tell me what frame to look at, I'll have a look. :-)
Message(s) : 8787
Message par MatthewJames5 » Dim Mai 12, 2013 1:07 am
http://aceattorney.sparklin.org/V6_Test ... 8120&debug Frame ID: 164 keep watching a bit longer, it occurs some time after that.
MatthewJames5
Message(s) : 30
Message par Enthalpy » Lun Août 17, 2015 6:55 pm
I'm closing this bug as an erroneous report. Checking against the editor data shows things work exactly as expected. I can reopen this if somebody observes a similar bug more clearly.
Message(s) : 4488
Retour vers AAOv6 Beta
