[Suggestion] Auto-centering text
- drvonkitty
Maybe it's just me, but I'm REALLY bad at centering text in the AAO6 editor manually. A way to have it auto-centered would greatly help me, and I hope it'd help many other people as well.
Re: [Suggestion] Auto-centering text
Ah yes, I plan to add the text alignment option at some point (left, right and center).
However, there will very likely be a limitation when I do it : text will follow that alignment event while it's being typed.
For example, if you type "Hello" right-aligned, it would look like
And NOT
That last one would be too much work - and would likely have a very big impact on performance.
H|
He|
Hel|
Hell|
Hello|
H |
He |
Hel |
Hell |
Hello|
- GanonZD
Are you sure there is no easy solution to accomplish the second option? Like actually typing out all the text from the beginning, but with transparent letters, and then changing them gradually to visible letters?
Ganon er kommt zum Dorf.
That's a possible approach, probably the best, but I wouldn't call it "easy", as it would require me to rewrite the whole text typing module.
And it'd have some tricky parts, like properly synchronizing tag processing with typing, and stuff like that. (and it would imply a memory overhead to have independent style settings for each character - which might be noticeable)
So this will not happen before a while.
- GanonZD
Well, there is also the option to use this system for all text. This would solve another problem, namely of the much-requested automatic line breaks. If all text is typed out beforehand, words don't change lines during the typing process.
I know, I thought about this too.
And I certainly don't intend to maintain two complex text typing stacks in parallel - it's clear that if I were to develop that, this new stack, though entirely different, would replace the current one and therefore be applied to all text.
As said, I could do it at some point but it'd be a lot of work, which I don't want to focus on at the moment.
