Tricks to a Cross-Examination: V6 Edition
Re: Tricks to a Cross-Examination: V6 Edition
Message par mercurialSK » Dim Juin 15, 2014 2:34 am
E.D.Revolution a écrit :Cross-Examination: Press-all-to-continue
Cross-Examination: Press to Obtain Evidence
Cross-Examination: Press all to Obtain Statement :)
Failing that, I like drvonkitty's idea.
mercurialSK
Message(s) : 297
Langues parlées: English
Message par E.D.Revolution » Dim Juin 15, 2014 3:55 am
I am a bit loath to call it an actual CE. Because in reality, there are three types of CEs: the normal, the press-all, and the press-to-continue. The CEs are defined by how one gets out of the CE block. In normal, an actual contradiction is needed, even if it's a press-to-object subtype, as opposed to the direct contradiction. Press-all is self explanatory. Press-to-continue is very specific in which you have to press certain statement(s) to escape.
I don't like Press-all-to-obtain only because most of what I have listed don't require pressing ALL the statements to get the last one.
I will rewrite this after there is a consensus.
EDIT: After thinking about it more, there are four types of CE structures, defined by how the player escapes the block:
Direct Contradiction: Also known as the Basic Cross Examination
Indirect Contradiction: Also known as press-to-object.
Press-All-to-Continue: You must press ALL the statements, including hidden if applicable, to escape the CE block.
Targeted Press-to-Continue: You must press certain statements in order to escape OR be able to escape. The Luke Atmey subtype is included in this.
So I will list that as a technique. What I mean by technique is an additional tool to structure your cross examination, such as amend or recursive contradiction or rotating statements.
E.D.Revolution
Message(s) : 5721
Message par TheDoctor » Dim Juin 15, 2014 5:25 am
Press-Multiple-to-Reveal-Statement is about the best I can come up with.
Image Image Image
TheDoctor
Message(s) : 987
Message par mercurialSK » Dim Juin 15, 2014 6:11 am
E.D.Revolution a écrit :I don't like Press-all-to-obtain only because most of what I have listed don't require pressing ALL the statements to get the last one.
Press X to obtain, then?
mercurialSK
Message(s) : 297
Message par E.D.Revolution » Dim Juin 15, 2014 10:12 pm
@TheDoctor, could you come up with a better riff on that?
@SK, sounds too close to "Press-to-obtain-evidence"
Still open for suggestions.
E.D.Revolution
Message(s) : 5721
Message par Spyromed » Dim Juin 15, 2014 10:15 pm
"Press Multiple; Obtain Statement."
Spyromed
Message(s) : 498
Message par TheDoctor » Lun Juin 16, 2014 12:52 am
Dig deep for info?
Image Image Image
TheDoctor
Message(s) : 987
Message par TheDoctor » Mar Juil 29, 2014 1:28 am
"Press-on-to-amend" could be another possibility, as "pressing on" implies continuation which may help differentiate it from "Press-to-amend," which implies only one press is needed.
Image Image Image
TheDoctor
Message(s) : 987
Message par E.D.Revolution » Mar Juil 29, 2014 3:05 am
I like that one the best so far.
E.D.Revolution
Message(s) : 5721
Message par DKJustice1 » Sam Août 27, 2016 12:16 am
Toggle the truth!
Press to amend.
Press to why?
How about these?
[size=85]Ace Attorney Poem.
What a crime is done.
Gumshoe's has come.
His name is Dick.
It's a point and click.
To find a clue
or maybe a few.
To made your point of view.
In the trial
where every one stares
the judge does glare.
Objections fly from everywhere![/size]
DKJustice1
Message(s) : 174
Genre: Féminin
Message par E.D.Revolution » Mer Déc 14, 2016 9:15 am
That discussion is closed, unfortunately.
E.D.Revolution
Message(s) : 5721
Précédent
Retour vers V6 Tutorials
