Tutorial: How to make a map with "MS Paint"
- Bad Player
- Spoken languages: American
- Dypo deLina
- Spoken languages: English, Dutch, German, French, Spanish, Al Bhed
Re: Tutorial: How to make a map with "MS Paint"
Uh... no, it's not.Bad Player wrote:dat first image is broken D:
EDIT:
チラセ・マギタ
~Married to Evolina deLuna~ <3
~Loving father to ZetaAzuel~
Proud creator of Cynder Janice, Rex Gladiorum, and Raimpius in Endless Time.
- VirtAnderson
He hotlinked it, so the server for court-records went bezonkers for a bit. You should probably upload it to another website then post that link.
- Spoken languages: ES/FR/EN/DE
Oh didn't pay attention to hotlinking at that time. Reuploading it
Em Dani podrias ponerlo en la secciòn española? o alguien podria abrirlo una secciòn de guias en la secciòn española? or explain with more details
Oh I can translate it for the spanish section. I'll do so tomorrow
Thanks Dani
How about this map?
I would recommend you to re-do the walls, since the quality looks a bit messed up. Did you set the room then resized it? That lowers the quality of your walls, be careful with that You should also watch for the corners of the icons, since they stand out from the background they are in (K) or interfere with surrounding objects (V) But it's still good for a start!
Also make sure your room is connected to other rooms, it looks like it's in the middle of the street or something xD
Thank you so much. This was so helpful. I made this little thing with this guide.
Terribly sorry for reviving this article, but how would I go about making it so that the victim, killer, and witness move like in the games? Would I make a .gif, or what?
Yup, a simple gif should do the job.
However, unless I'm mistaken, the witness markers never actually move in the games, they just sorta jump around from point A to point B. To do this, you wouldn't even need a gif. Simply switching between two different images with altered marker positions would be easier and would achieve the same effect.
- DAYUMM
Thanks for the guide! I have not finished this, but its good enough at the moment. Also i need some help with creating the veranda text properly. every time i do it, the letters turn all retarded!
- Attachments
- Hambar_clinic.png (2.36 KiB) Viewed 6054 times
- VirtAnderson
AquaAce, I know for certain they move in Dual Destinies, and I kind of remember them moving in Trials and Tribulations.
