[Bug][P][✗] Custom music cuts out after a minute
All discussions regarding the AAOv6 Beta, be it bug reports or suggestions, should be posted in this section.
ApolloGrimoire
Post by ApolloGrimoire »
The custom music for some reason cuts out about a minute in when they're played.
The loading screen shows being fully loaded.
Reason: Closed bug.
Like the creator of Final Fantasy, I'm better at telling a story.
If you need help animating Ace Attorney sprite sheets, I'm your man.
Case 1 - Nursing the Turnabout: Trial Former, Trial Latter
Greatest Weakness - Mis;use of; Semi;colons
Meph
Re: [Bug][P] Custom music cuts out after a minute
Post by Meph »
Which browser were you using? Does it still happen when you use a different browser? Does it always happen?
ApolloGrimoire
I'm using the latest version of Google Chrome on Windows Vista 64-bit.
Same thing happened when it was done for the french beta testing release.
Not sure if the same applies for the music in the editor though, will update shortly.
The preloaded music in the editor works fine.
Custom sound effects aren't affected either. :)
Very major bug found: Custom music won't play in cross-examinations. At times... it's very finicky. :random: :random: :random:
Edit 3: Now it seems it doesn't play at all in some places. :cry:
Re: [Bug][P][✗] Custom music cuts out after a minute
Bug closed.
It's not possible to reproduce this one, and given that there have been no further reports of this in over two years, this has either been fixed silently, or was a problem with the host.
TheDoctor
Post by TheDoctor »
Actually, this sounds like the same bug that I mentioned when I was trying to test Google Drive as a viable music host.
Image Image Image
Given that the topic you had for that was deleted, I'm going to need more information.
ApolloGrimoire was trying to report multiple bugs here. At a minimum, I need to know which one you're talking about.
TheDoctor
Post by TheDoctor »
Just that the music was cutting out about a minute into the track. I haven't been able to replicate the bug since then though. I just thought it was worth mentioning.
Image Image Image
Are you talking about in the player, or the in-editor preview?
TheDoctor
Post by TheDoctor »
The player.
Image Image Image
Okay... I'm able to use Google Drive for hosting without any cutout errors. Without a demo, there isn't much to be done here.
