Misc. Questions
Re: Misc. Questions
AAM, of course if you want to run anything more than the static testing, you need an HTTP server configured to execute PHP, as written in the readme files.
The simplest way to setup a PHP-capable webserver on Windows is to use a bundle installer like easyphp (take the development server) or WAMP.
Those will install the Apache HTTP server along with the PHP modules - approximately the same setup as the AAO server, and most of the webservers in the world I guess.
Apparently, as Enth pointed out there is a basic webserver included along with php now - I didn't even know about it, so I don't know what it's worth, I guess it works fine.
But anyway, a tool like WAMP or EasyPHP may be simpler for discovering the basic environment of a web developer, and will open more possibilities as well : those also come with a MySQL engine, so you'd even be able to install a fully integrated AAO version if you needed to.
- Spoken languages: English, français, un poco de español, עברית
Re: Misc. Questions
I use Mac, not Windows, and the built-in uses the terminal/command line which is easily accessible to me. I'm in process of installing it.or at least im trying to Git is installed and working.
Re: Misc. Questions
Ah, good, if you are using a system with a good terminal that's fine. Let's try the built in then !
I run Linux most of the time myself, but most people run Windows - and the windows command line terminal is terrible.
- Singidava
- Spoken languages: Suomi, English & 日本語
Re: Misc. Questions
As a side note, if I personally have to use Windows terminal I'll just use Git Bash instead. Essentially does the same things but has also multiple Unix commands. I guess you could just add them to your Path and use cmd too but that's bothersome and Path has limited length anyway. Plus being able to copy stuff is nice.Unas wrote:I run Linux most of the time myself, but most people run Windows - and the windows command line terminal is terrible.
- kwando1313
- Spoken languages: English, Français (un peu), Ancient Belkan
Re: Misc. Questions
Yeah, I use git bash on my computer.
Too lazy to open up a VM just to program in soooo... xP
Avatar made by Rimuu~
"The Knight of the Iron Hammer, Vita, and the Steel Count, Graf Eisen. There's nothing in this world we can't destroy."
Re: Misc. Questions
As I said, I use Mac. Which file do I download? .tar.bz2, .tar.gz, or .tar.xz
Re: Misc. Questions
Well, those are basically the same, only the compression of the archive differs. But anyway, I think all those available on the official website are Linux builds.
For OSX, you should have a look here : http://php-osx.liip.ch/
If you want to install php 5.5, you can simply run
in your terminal : it will fetch the package installer from this site and run it.
curl -s http://php-osx.liip.ch/install.sh | bash -s 5.5
Re: Misc. Questions
I've stumbled across a bug while testing the converter:
Some Def1 frames have image lines like 'salle_d_audience/salledattente,PERhttp://aceattorney.free.fr/Ressources/Images/persos//no.gif'. The problem is http://aceattorney.free.fr/Ressources/I ... os//no.gif, which in-context is meant to be just no, but Def1 doesn't realize this.
Is this a one-off problem, or part of a larger class of converter issues?
Re: Misc. Questions
This looks more like a bug in the V1 or V2 editor. Looks like the editor interpreted the "no character" information as an external picture and stored it as such, which does not make sense. The trial data itself is wrong.
The converter could probably recognise this specific issue on fix it on the fly (hardcoding a replacement of "PERhttp://aceattorney.free.fr/Ressources/Images/persos//no.gif" by "no" before handling the field or something), but it would be quite clunky anyway.
I don't think you should focus on these issues though : if a bug is ever reported in a Def1 trial, we'll see, but I dooubt people care about many of those.
For the record, when AAO was first released in English and became widely known it was already running the V3 editor and using Def4 format... So fixing a V2 bug in Def1 files is probably not that important.
- kwando1313
Re: Misc. Questions
Also, a suggestion about the issue tracker...
Currently, we can only assign issues to Unas and AceAttorneyOnline. Would it be possible to add people (like me) to that list so we can at least assign issues to ourselves and make that type of management easier?
Re: Misc. Questions
I could beam probably wrong, but I think assigning issues is reserved to people who can modify the repository directly. Iunno if there's a way to change that in settings.
Re: Misc. Questions
It should be possible if Unas gives us read permissions. Just enough so that we can be assigned projects, but not enough that we can edit anything.
Since Unas was going to let us edit the Wiki as well (see Project Listing topic), we may also get writing power, if "write" doesn't include writing files.
Re: Misc. Questions
I thought I couldn't with a free bitbucket account, but it turns out I can actually.kwando1313 wrote:Currently, we can only assign issues to Unas and AceAttorneyOnline. Would it be possible to add people (like me) to that list so we can at least assign issues to ourselves and make that type of management easier?
Enth is right, it just only displays people who have explicit permissions on the repository : I just explicitly set a "read" permission on the repository (which you implicitly had anyway since the repository is public) for Kwando, Enth and AAM, and you now all appear in the list.
As far as the wiki is concerned, I intended to make it freely editable by anyone, like any wiki, rather than specifically giving you write permissions.
- kwando1313
Re: Misc. Questions
Yeah, I figured that it would be possible because I've used bitbucket for work, so I figured the permissions logic would work in a similar manner to JIRA. xP
The annoying thing is that only the reporter of an issue can only assign who is on the issue, but... It's not a major major concern. xP
Re: Misc. Questions
If need be, we'll just make a topic to request assignments.
